Bush Hog Proof Lights
/ Bush Hog Proof Lights #1
BWa
Brockton / West Bridgewater Ma.
2002 JD 990
After much effort I hope that I can now post what I did to mount lights that would not be in the way or to get busted off by trees and branches . I have a JD990, but this will work for any tractor with a ROP and can be fitted to mount with a canopy.
Before this last jump in scrape steel I went to the local steel shop and got a scrape piece of steel tube that was big enough to mount a set of Driving lights in , I cut it so I had enought to make two sets of mounts , 4"x5"x6" . I drilled two holes that matched the canopy mounting holes on the ROP, one hole to run the wires for the light , and one one hole on the top to mount the light inside of the tube . I painted them to match the tractor color , the mounted them using 12mm bolts . the wiring I run down the inside of the ROP and back up under the seat to the main wire harness were I back wired to the fuse block , making sure to have conectors at the split point just like the factory harness for that possible need for service . I rrun the lights through the factory switch , time will tell if I will need to replace this and up grade to a relay system for the lights .
Bill G.
/ Bush Hog Proof Lights #4
OMG! You've been hangin around with Henro, and drilled your ROPS didn't you! Seriously, that looks like a good arrangement. The only problem will come if the tractor turns over, one will probably be a little mashed, but that's not terrible. Looks like it will give really good protection in those woods. Good work. John
/ Bush Hog Proof Lights #5
While my opinion is completely unsolicited, with that style of ROPS with the 90 deg. corners, I prolly woulda put them on the inside corner ...
/forums/images/graemlins/smirk.gif
LOL ...
Lost my home PC' , but No ROP was drilled for this install ... the JD990 has pre-drilled and threaded 12mm hole for the install of canopies or cabs ..... ..
as for damage to them if it is rolled over I am thinking I will be wooried about something more than a busted light ... /forums/images/graemlins/shocked.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/tongue.gif
Bill G.
/ Bush Hog Proof Lights #7
Donw boy...Down! You needn't defend what was a nice install. My opinion, nothing to do with rolling the machine, was based on the fact that I can pretty much guarantee on my land that those light would take a beatin bein on the outside of the ROP ... thaz all.
Perhaps this thread should have been titled:
"NO ROPS HAVE BEEN HARMED IN THE MAKING OF THIS THREAD" ... or sumpin.
/ Bush Hog Proof Lights #8
Nice, it gives me some ideas, like using driving lights for a car or maybe even using tractor utility lights with a togleswitch on them.
/ Bush Hog Proof Lights #9
</font><font color="blue" class="small">( as for damage to them if it is rolled over I am thinking I will be wooried about something more than a busted light ... )</font> LOL. I bet you would be. I hope you never find out. Nice job, I think they will be strong enough to resist damage even on the outside. John
LOL, /forums/images/graemlins/grin.gif Dap / Doug ...
No problem it is some times hard to understanding feel on the chat boards to when something is written in fun or fact ,,, I am sorry if it came out as defensive. /forums/images/graemlins/blush.gif.. I had hoped to be abit more on the humor / explainive side of how and what I have done with the hope of giving back a little for what I have learned and keep learning here from all the members ... /forums/images/graemlins/laugh.gif...
Thank You All ...
Bill G.
2016 TAKEUCHI TB240 EXCAVATOR (A65053)
2016 TAKEUCHI...
Landhonor ATS-RT15R Mini Excavator (A66285)
Landhonor...
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
New/Unused ATS Grass Proof Cloth (A65583)
New/Unused ATS...
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
Landhonor 65' Extension Cord Reel (A66408)
Landhonor 65'...
