Bush Hog on Front of BX
   / Bush Hog on Front of BX #31
If you put a drive shaft on it, how are you going to control keeping from lifting it too high by accident? Just curious. :)
post #5 ?
Driveshaft would need sufficient overlap to accommodate FEL height adjustments. Would need a chain or something to limit the height the FEL could rise.
Might want to rig up a cushion of sorts so it doesn't scare you.
Or there are other options.
   / Bush Hog on Front of BX #32
was thinking about mounting a 3 point hitch system on the front of my DA 5215 but was going to use a hydraulic motor to drive it as well as the snow blower.
   / Bush Hog on Front of BX #33
was thinking about mounting a 3 point hitch system on the front of my DA 5215 but was going to use a hydraulic motor to drive it as well as for the snow blower.
   / Bush Hog on Front of BX #34
post #5 ?
<img src="http://www.tractorbynet.com/forums/files/customization/428380-bush-hog-front-bx-rope-jpg"/>
Lol!!! That would do the trick for sure!
   / Bush Hog on Front of BX #36
I've seen youtube video of this in Europe. Search "deere 3520" "deere 3720". I cannot connect to youtube now or I would send the link. Not sure if there is a bush hog type, but I've seen the flail for sure.
http://youtu.be/eaY23oC6yjc
So how would one go about getting this? This is obviously to big for a BX but I have an L series and would get this
try this web site: 48" Hydraulic Offset Flail Mower EFGCH125 - Value Leader Implements
The 48" would work on a BX. I have come to the most practical front drive solution I think; Use a flexible shaft from the BX MMM PTO and install a 1:5 speed reducer ahead of the mower gear box. $ $ $ the only problem. Their price is not much more than the LP I have. I can dream can't I!
Ron
   / Bush Hog on Front of BX #40
Ron
I think you may be on the right track. This video may help with the linkage issues, you could just use a chain on the fel to raise/lower the whole unit. (yea, yea, I realize this one is hydro...)
Rough Cut Mower - ProManPTO
UNUSED 1RMC MASSAGE CHAIR (A57193)
UNUSED 1RMC...
E-Z-Go Workhorse Utility Cart (A55851)
E-Z-Go Workhorse...
12" PIN ON BUCKET (A52707)
12" PIN ON BUCKET...
202473 (A54757)
202473 (A54757)
John Deere BD1108 (A50123)
John Deere BD1108...
2017 Ford Transit 350 Handicapped Van (A53422)
2017 Ford Transit...
