Bush Hog on Front of BX
   / Bush Hog on Front of BX #31
If you put a drive shaft on it, how are you going to control keeping from lifting it too high by accident? Just curious. :)
post #5 ?
Driveshaft would need sufficient overlap to accommodate FEL height adjustments. Would need a chain or something to limit the height the FEL could rise.
Might want to rig up a cushion of sorts so it doesn't scare you.
Or there are other options.
   / Bush Hog on Front of BX #32
was thinking about mounting a 3 point hitch system on the front of my DA 5215 but was going to use a hydraulic motor to drive it as well as the snow blower.
   / Bush Hog on Front of BX #33
was thinking about mounting a 3 point hitch system on the front of my DA 5215 but was going to use a hydraulic motor to drive it as well as for the snow blower.
   / Bush Hog on Front of BX #34
post #5 ?
<img src="http://www.tractorbynet.com/forums/files/customization/428380-bush-hog-front-bx-rope-jpg"/>
Lol!!! That would do the trick for sure!
   / Bush Hog on Front of BX #36
I've seen youtube video of this in Europe. Search "deere 3520" "deere 3720". I cannot connect to youtube now or I would send the link. Not sure if there is a bush hog type, but I've seen the flail for sure.
http://youtu.be/eaY23oC6yjc
So how would one go about getting this? This is obviously to big for a BX but I have an L series and would get this
try this web site: 48" Hydraulic Offset Flail Mower EFGCH125 - Value Leader Implements
The 48" would work on a BX. I have come to the most practical front drive solution I think; Use a flexible shaft from the BX MMM PTO and install a 1:5 speed reducer ahead of the mower gear box. $ $ $ the only problem. Their price is not much more than the LP I have. I can dream can't I!
Ron
   / Bush Hog on Front of BX #40
Ron
I think you may be on the right track. This video may help with the linkage issues, you could just use a chain on the fel to raise/lower the whole unit. (yea, yea, I realize this one is hydro...)
Rough Cut Mower - ProManPTO
2020 JOHN DEERE 50G EXCAVATOR (A52707)
2020 JOHN DEERE...
1992 Ford L900 Cab Chassis with Low Milage Cummins (A55315)
1992 Ford L900 Cab...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
John Deere 5103 (A53317)
John Deere 5103...
CFG Industrial QH12R (A56469)
CFG Industrial...
