Bush Hog on Front of BX
   / Bush Hog on Front of BX #51
For adapting your mower, here is a 40HP gearbox that is rated for 1000RPM input: 40 HP OMNI GEAR ROTARY CUTTER GEARBOX 250618
Aaron Z
I was also thinking that replacing the gearbox altogether may be a simpler solution than finding a 4.6:1 gear reducer that can handle that power. You would need to find out what the gear ratio is on the hog and then try to match the mower speed with the new gearbox running off the mid PTO.
The one Aaron found is only rated to 1000 RPM. Here is one rated to 1800 RPM and has a 1:1 ratio. Gets you a bit closer.
   / Bush Hog on Front of BX #52
Page 27 of the owners manual (http://www.landpride.com/ari/attach/lp/public/manuals/312-556m.pdf) says its a 1:1.93 gearbox, so if you could find a 1:1 bush hog gearbox that was rated for 2500 RPM, it should work.
I looked at that one, but it is not a bush hog gearbox and as such, it doesn't have the beefed up bearings on the bottom, so mounting a bush hog stump jumper to it would probbaly break something in short order.
Aaron Z
2018 Ford Escape (A56859)
2018 Ford Escape...
34015 (A53421)
34015 (A53421)
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2015 Peterbilt 320...
Metal Bigfoot Lawn Art (A55853)
Metal Bigfoot Lawn...
***No power to dash*** Year: 2015 Make: Ford Model: Transit Van Vehicle Type: Van Mileage: CNV (A55852)
***No power to...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55315)
Michelin CARGOXBIB...
