Bush Hog on Front of BX
   / Bush Hog on Front of BX #51
For adapting your mower, here is a 40HP gearbox that is rated for 1000RPM input: 40 HP OMNI GEAR ROTARY CUTTER GEARBOX 250618
Aaron Z
I was also thinking that replacing the gearbox altogether may be a simpler solution than finding a 4.6:1 gear reducer that can handle that power. You would need to find out what the gear ratio is on the hog and then try to match the mower speed with the new gearbox running off the mid PTO.
The one Aaron found is only rated to 1000 RPM. Here is one rated to 1800 RPM and has a 1:1 ratio. Gets you a bit closer.
   / Bush Hog on Front of BX #52
Page 27 of the owners manual (http://www.landpride.com/ari/attach/lp/public/manuals/312-556m.pdf) says its a 1:1.93 gearbox, so if you could find a 1:1 bush hog gearbox that was rated for 2500 RPM, it should work.
I looked at that one, but it is not a bush hog gearbox and as such, it doesn't have the beefed up bearings on the bottom, so mounting a bush hog stump jumper to it would probbaly break something in short order.
Aaron Z
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
UNUSED FUTURE 14' WROUGHT IRON BI-PARTING GATE (A57193)
UNUSED FUTURE 14'...
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
