Bush Hog Maintenance
/ Bush Hog Maintenance #1
Jer
So. California
Two tractors..both Mitsubishi. MT160D 4WD with a Brush Cutter. The other is a MT1601 4WD with a loader
I’ve purchased a tractor with a 48” rotary Texas Belton Continental “Bush Hog”. I think its about 15 or 20 years old. I do not have a Manuel with the machine and would like to know what type oil to use if needed in the transfer case on the rear and also what other maintenance may be required.
Thanks, Jerry S.
/ Bush Hog Maintenance #2
You probably will need to use 80w to 90w gearbox oil.
As for other maintenence, find all grease fittings and make sure to keep them well greased.
/ Bush Hog Maintenance #3
I agree with Dave, keep the gearbox up to level and keep the blades sharp. Good Cutting!
2018 SKYJACK SJ1056 TELEHANDLER (A65643)
2018 SKYJACK...
Morbark Eager Beaver 1215 (A63689)
Morbark Eager...
213088 (A64276)
213088 (A64276)
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
2013 KENWORTH T660 SLEEPER TRUCK (A65643)
2013 KENWORTH T660...
John Deere 700 H Dozer (A62679)
John Deere 700 H...
