bush hog help
/ bush hog help #1
horses2
Bronze Member
Westminster, Md
Kubota M471D
I have an older model bushhog squealer SQ60. I have managed to bend up the a-frame assembly (Homer Simpson moment). I have gotten the two side pieces that mount to the deck and top link straightened back to original shape, but I have broken the support piece that ties those two pieces together and provides additional mount support for the lift pins.
I have searched for just that piece and cant seem to find it. I have found A frame weldments that appear to be updated versions? for the more experienced on the web site, I am not good enough to weld the piece back together and my fabrication skills have not yet transferred to heavy metal.
anyone have a source for this "crossmember'?.
thanks,
/ bush hog help #2
If you have no luck with a replacement part then perhaps taking in your pieces to a local welding shop or perhaps a machine shop might be a option. They could use what you have for a pattern.
/ bush hog help #3
You could just grab some steel at tractor Supply. You can cut it with a grinder and metal blade and bend it in a vise. You said you don't weld, so just drill and attach with bolts.
/ bush hog help #4
Pictures would probably help. Yeah, we want to see the results of the "homer" moment lol.
2006 INTERNAITONAL 7600 6X4 T/A DUMP TRUCK (A66091)
2006 INTERNAITONAL...
2019 International LT625 Sleeper 48" (A62613)
2019 International...
2018 Ram 1500 Crew cab (A59230)
2018 Ram 1500 Crew...
1968 MTTI Lowboy Trailer (A62613)
1968 MTTI Lowboy...
2014 Grand Caravan (A62679)
2014 Grand Caravan...
CASE 105C (A62177)
CASE 105C (A62177)
