Bush Hog blade replacement
/ Bush Hog blade replacement #1
yanmars
I had a bolt come out of my bush hog and one blade came off. The threads are pretty mangled. I have a replacement. Any trick to replacing it by myself. I think I can get the new in and started, unsure how much torque I will need to tighten it down and how to hold the blade to do that. I only have hand tools. Any ideas are welcome. Any reason to add lock tite?
/ Bush Hog blade replacement #2
...Any reason to add lock tite?
Yea, So it doesn't happen again... :D :D
I had trouble getting the thread started... bolt falling out. I did it myself and it wasn't fun. Do you have another set of hands?
I think I ended up duck taping the bolt in place to get the nut on.
Thanks for the information. I will see what I can do, if not I can take it off and bring it to my tractor shop.
/ Bush Hog blade replacement #5
I stick the bolt through and let the weight and leverage of the blade bind the bolt in the hole. Tighten with a breaker bar. Did the new bolt come with a lock washer? I've never had an issue with using a lock washer. Another option would be to drill a hole in the bolt to use a cotter pin the keep the nut from coming off.
It did come with a lock washer. Access is through a hole in the top of the mower deck, might be hard to get a cotter pin in. Also the stump jumper is pretty tight to the deck so not much room underneath to gain access.
2012 Ford F-250 6.7L Diesel, 4WD (A62679)
2012 Ford F-250...
Linx EQ07020RS 20ft Trailer (A65640)
Linx EQ07020RS...
2022 EZ-GO ELITE...
John Deere Grill Guard (A65640)
John Deere Grill...
2007 Ford F-450 Flatbed Truck, VIN # 1FDXF46P77EA72394 (A65563)
2007 Ford F-450...
(4) Drive Tires off Kinze 3000 Planter (A65640)
(4) Drive Tires...
