bush hog blade question
/ bush hog blade question #1
horses2
Westminster, Md
Kubota M471D
So I need replacement blades for my older bushhog. tractor supply has the correct blade (length, offset, etc) however the cutting edge is about 3 inches shorter than the original. will this make a difference? I was told the difference was so bushhog wouldn't come after them for copying a part. I was a bit skeptical about that as the auto parts industry is all about copying parts.
the tag on my bush hog has a model number of S050R (might be O or 0). blade length is 24.5", width is 3", cutting edge is 9.25", offset about 2".
thanks,
/ bush hog blade question #2
Make sure the bolt holes are the same
I had to go OEM because no aftermarket blades had the proper bolt hole size. bjr
/ bush hog blade question #3
thanks,
No. The outer 6" of the knife handles all the cutting up to about 9 mph. If you go faster than that youll need more of the blade sharpened..
/ bush hog blade question #4
I have been shopping for new blades for my OLD Woods 5' Rotary Mower.
I bought it used, in poor condition over 20 years ago. I replaced the rusted deck and fabricated a new Stump Jumper. Now it needs new blades.
I found the blade part number and called local Woods Dealer was told it was out of stock and would take about 2 weeks to get.
I googled part number and found dealer in Pa. with them in stock and ordered them.
They said the blades will ship today and I should have them in 2 days!!
If you have the part number you should be able to get the right blades.
/ bush hog blade question #5
thanks,
I really don't think the 3" difference will make a difference in most cases. Ken Sweet
Sometimes you just need to go to the source. Took the old blade to Messicks, they had the exact bushhog OE part. Turns out my unit uses a #36 blade. price was less than aftermarket, and the cutting edge was exact same length. solved!!
should have just gone there first.
/ bush hog blade question #7
Messicks is our "go to" vendor for oem parts. Great company!! Ken Sweet
/ bush hog blade question #8
Glad you found a set of OEM blades at a good price. The blades for my woods ds96 aint cheap. And I couldnt find anything aftermarket either.
As others said though, that 3" aint gonna really make a difference though. Look at them blades after you do some hard cutting. You can abuse that bushhog and have no almost no edge left, and I bet that inside 3" of blade will still look almost new.
/ bush hog blade question #9
Altho unused beyond about 5", secondary collisions happen inward of that and will give the false impression that an edge there actually does something. The real issue is that that extended superfluous edge is material subtracted from the blade mass, causing a small detriment in blade performance. ... Perhaps the OEM blade is better steel though. THAT would be worth it.
/ bush hog blade question #10
I found the blades for my OLD Woods Rotary Cutter at MESSICK'S in Pa.
I ordered them and had them FEDEX in TWO DAYS!!!
I am VERY HAPPY with their fast shipping!
Two blades- $74.62 (similar to prices on ebay) Shipping- $18.50
No connection to them BUT I will post their phone number- 800-222-3373
/ bush hog blade question #11
I got a pair of blades for my Woods Cadet at Tractor Supply. I belive they're intended for a Bush Hog and were too long for the Woods. I thought I'd have to use a cut off wheel to shorten them and was surprised to find that my metal cutting bandsaw went right through them. I hope to install them this week.
/ bush hog blade question #12
Here are pics of the old and new blades.
They probably would have lasted another 10 years! But I am not that guy! :)
It cuts like a Finnish Mower now.
/ bush hog blade question #13
Yea, you were due to change them
/ bush hog blade question #14
Are you sure you couldn't eke another 5 years out of them (Grin)?
You were overdue!
/ bush hog blade question #15
You got your monies worth out of the old set. Does anyone have a good
idea of use for old blades? I probably have 50 sets in a stack. I have cut
the hole end off before and made really big washers.
/ bush hog blade question #16
How hard are the blades? I have discovered that once the cutting edge gets rounded back they don't cut nearly as good as they did when the cutting edge was straight.
/ bush hog blade question #17
If you need another 3" of sharp edge, whip out the old 7" angle grinder and sharpen it back a few more inches.
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
2004 Ford F-550 Single Cab Flatbed Truck, VIN # 1FDAF56P94EC72605 (A65563)
2004 Ford F-550...
451 New Holland Sickle Bar Mower (A66408)
451 New Holland...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A64280)
1994 CHEVROLET...
(INOP) 2022 MACK MD6 WATER TRUCK (A64280)
(INOP) 2022 MACK...
New/Unused Landhonor Power Rake (A65583)
New/Unused...
