Bush Hog 2515 wide angle double yoke repairable?
   / Bush Hog 2515 wide angle double yoke repairable? #1
TigerFanatic1
North Louisiana
Kubota M9540
I have a lot of movement and visible damage in the wide angle double yoke, likely from getting stuck and damaging from angle. I haven't attempted to take apart yet, because I can't find any bearings or repair kits. The wide angle double yoke looks to be part #76357.
   / Bush Hog 2515 wide angle double yoke repairable? #2
The cross kits are PN: 64663 anywhere from $46 to $125 depending on where you buy. Messicks has the pricier Bushhog cross, Amazon the cheaper. Most good bearing shops should be able to match.
Could also measure cap diameter and cross length to look up replacement. Measurements are metric. Cheaper route.
I’m probably misidentified it. Below is a picture
   / Bush Hog 2515 wide angle double yoke repairable? #4
   / Bush Hog 2515 wide angle double yoke repairable? #5
2018 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2018 Allmand...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
30050 (A53424)
30050 (A53424)
2019 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2019 Allmand Bros...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
