Bush Hog 2515 wide angle double yoke repairable?
   / Bush Hog 2515 wide angle double yoke repairable? #1
TigerFanatic1
North Louisiana
Kubota M9540
I have a lot of movement and visible damage in the wide angle double yoke, likely from getting stuck and damaging from angle. I haven't attempted to take apart yet, because I can't find any bearings or repair kits. The wide angle double yoke looks to be part #76357.
   / Bush Hog 2515 wide angle double yoke repairable? #2
The cross kits are PN: 64663 anywhere from $46 to $125 depending on where you buy. Messicks has the pricier Bushhog cross, Amazon the cheaper. Most good bearing shops should be able to match.
Could also measure cap diameter and cross length to look up replacement. Measurements are metric. Cheaper route.
I’m probably misidentified it. Below is a picture
   / Bush Hog 2515 wide angle double yoke repairable? #4
   / Bush Hog 2515 wide angle double yoke repairable? #5
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
UNUSED LANDHONOR 5/16" 7' G80 DBL CHAIN SLINGS (A54757)
UNUSED LANDHONOR...
UNUSED LANDHONOR FW-13-15000G HYD WINCH (A54757)
UNUSED LANDHONOR...
GMC 3500 Extended Cab 4WD Pickup Truck - 6L V8 Gasoline Automatic (A55218)
GMC 3500 Extended...
