Burning stumps
/ Burning stumps #1
challengertn
Southern middle Tennessee
MF 135 soon to be Kubota
Anybody have any tips that would help when burning out stumps. These stumps are large and would take a dozer to dig out and they are in a place that would make the damage done by a dozer not worth getting rid of the stumps.
/ Burning stumps #2
Auger/drill a bunch of holes in them and maybe pour some kerosene in the holes, give it time to soak in good. Pile brush on top and get a good fire going all day long. Might take more than one burning.....I have had fair results with this method.
Ben
/ Burning stumps #3
My uncle drilled holes in some of his and poured something inside the hole (forget what it was). As I recall, he said it would either hasten the deterioration from the inside... or that it was flammable and he was going to ignite it a day later and let the stump smolder underground.
For some reason, now that I type it out, I think it was more of the latter (smoldering) than rotting.
Perhaps he was going to soak with kerosene?
Anyways, that's all I know in it... I ended up popping them out with my backhoe and he never did it.
Richard
/ Burning stumps #4
Dang that slowrev is a fast typest! /forums/images/graemlins/shocked.gif jumped right in front of me
/forums/images/graemlins/grin.gif
/ Burning stumps
If I remember correctly it is saltpeter that you pour into the holes to hasten decay but I've never tried it. When I burn them I have a problem with the stump's fire suffocating under it's own ashes.
/ Burning stumps #6
I bought a piece of 4' metal culvert 4' long, they use them as drywells buried and filled with rock. Set that puppy over a stump and build a good fire in it and it will cook a stump pronto and contain the fire so you won't burn the countryside. Works great.
/ Burning stumps #7
I have used "Stump-Out" in the past. You need to add kerosine, but it does work well.
Info
Gary
/ Burning stumps #8
Small walk behind stump grinders work great. Very little turf damage and they grind the stump into mulch. Then all you have to do is dig out a little of the chips and add soil, and your ready to grass over the stump....
/ Burning stumps #9
We have had good results with setting a piece of tin around the stump and spreading a few bags of charcol over the stump and set it on fire. It will usually smolder for two or three days and anything that is left is easily removed. /forums/images/graemlins/smile.gif
/ Burning stumps #10
Someone once told me copper sulfate was the stuff to pour in them.
/ Burning stumps #11
I tried one of those stump rot things and those stumps are still there.
What worked well for me was to cut a cross hatch pattern in the stump with my chain saw as deep and as busy as I could.
Then I piled 3-5 big bags of charcoal briquets on top of the stump and let them cook for as long as possible. This worked pretty good.
It still takes a while to do if you have a lot of stumps and I was a little wary about leaving 4-5 stumps cooking for so long but it did work.
For my next 50 trees it's going to be a dozer and I'm going to get everything ripped out of the ground.
/ Burning stumps #14
If its within extension cord reach on a weekend youll be around to supervise it take a half of a 55gallon drum with both ends removed and cut a door in the side of it. Take and put it on some rocks that lift it 1 to 2 inches off the ground andcut a hole in the side of the barrel to let a cheap window fan sit there and blow on the coals. I did this a few months ago and it works great the coals never completely die out.
2014 John Deere 310SK 4x4 Extendahoe Loader Backhoe (A61572)
2014 John Deere...
DEWALT 30 GALLON COMMERCIAL AIR COMPRESSOR (A64281)
DEWALT 30 GALLON...
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
2012 GMC Sierra 1500 SLE 4x4 Crew Cab Pickup Truck (A61573)
2012 GMC Sierra...
2001 Ford F-150 Crew Cab Pickup Truck (A61573)
2001 Ford F-150...
2005 Manac 48' x 102" Aluminum Fixed Spread Axle Trailer (A62613)
2005 Manac 48' x...
