Burning stumps
/ Burning stumps #1
challengertn
Southern middle Tennessee
MF 135 soon to be Kubota
Anybody have any tips that would help when burning out stumps. These stumps are large and would take a dozer to dig out and they are in a place that would make the damage done by a dozer not worth getting rid of the stumps.
/ Burning stumps #2
Auger/drill a bunch of holes in them and maybe pour some kerosene in the holes, give it time to soak in good. Pile brush on top and get a good fire going all day long. Might take more than one burning.....I have had fair results with this method.
Ben
/ Burning stumps #3
My uncle drilled holes in some of his and poured something inside the hole (forget what it was). As I recall, he said it would either hasten the deterioration from the inside... or that it was flammable and he was going to ignite it a day later and let the stump smolder underground.
For some reason, now that I type it out, I think it was more of the latter (smoldering) than rotting.
Perhaps he was going to soak with kerosene?
Anyways, that's all I know in it... I ended up popping them out with my backhoe and he never did it.
Richard
/ Burning stumps #4
Dang that slowrev is a fast typest! /forums/images/graemlins/shocked.gif jumped right in front of me
/forums/images/graemlins/grin.gif
/ Burning stumps
If I remember correctly it is saltpeter that you pour into the holes to hasten decay but I've never tried it. When I burn them I have a problem with the stump's fire suffocating under it's own ashes.
/ Burning stumps #6
I bought a piece of 4' metal culvert 4' long, they use them as drywells buried and filled with rock. Set that puppy over a stump and build a good fire in it and it will cook a stump pronto and contain the fire so you won't burn the countryside. Works great.
/ Burning stumps #7
I have used "Stump-Out" in the past. You need to add kerosine, but it does work well.
Info
Gary
/ Burning stumps #8
Small walk behind stump grinders work great. Very little turf damage and they grind the stump into mulch. Then all you have to do is dig out a little of the chips and add soil, and your ready to grass over the stump....
/ Burning stumps #9
We have had good results with setting a piece of tin around the stump and spreading a few bags of charcol over the stump and set it on fire. It will usually smolder for two or three days and anything that is left is easily removed. /forums/images/graemlins/smile.gif
/ Burning stumps #10
Someone once told me copper sulfate was the stuff to pour in them.
/ Burning stumps #11
I tried one of those stump rot things and those stumps are still there.
What worked well for me was to cut a cross hatch pattern in the stump with my chain saw as deep and as busy as I could.
Then I piled 3-5 big bags of charcoal briquets on top of the stump and let them cook for as long as possible. This worked pretty good.
It still takes a while to do if you have a lot of stumps and I was a little wary about leaving 4-5 stumps cooking for so long but it did work.
For my next 50 trees it's going to be a dozer and I'm going to get everything ripped out of the ground.
/ Burning stumps #14
If its within extension cord reach on a weekend youll be around to supervise it take a half of a 55gallon drum with both ends removed and cut a door in the side of it. Take and put it on some rocks that lift it 1 to 2 inches off the ground andcut a hole in the side of the barrel to let a cheap window fan sit there and blow on the coals. I did this a few months ago and it works great the coals never completely die out.
2004 International 4300 Fuel & Lube Truck 593775 (A62613)
2004 International...
UNUSED X-STAR 300 GALLON FUEL TRAILER (A64280)
UNUSED X-STAR 300...
2022 EZ-GO ELITE...
2019 Ford F450 4x4 Service Truck w/ Tommy Gate (A62613)
2019 Ford F450 4x4...
Kubota V3300-T-E2BG Turbo Diesel Engine - 3.3L - Pump Takeout - Tier 2 (A63689)
Kubota...
PALLET OF (3) CONCAVES OF CASE 2388 (A64281)
PALLET OF (3)...
