Bump up lift capacity of L3400/LA463 Loader
   / Bump up lift capacity of L3400/LA463 Loader #81
Jimainiac:
The fill port for the hydraulic fluid is way above the fill level on my L3300, at least a foot. So the vacuum won't pull any fluid in. All it needs is a few inches. The vacuum will pull hard while the hydraulic system is closed, but when you unscrew the pressure relief port, the air is bubbled up through the hydraulic fluid and goes out through the vacuum. Give it a try when you get the proper gauge. I got mine from Northern Tools for $20.
   / Bump up lift capacity of L3400/LA463 Loader #82
jfay, thanks for that explanation of the vacuum process, it makes more sense to me now. In my shop manual it shows the gauge being hooked up to the actual pump area, next to the fitting that contains the relief valve. I wonder if the system pressure is the same no matter where it's measured? Any hydraulic engineers care to comment on that?
   / Bump up lift capacity of L3400/LA463 Loader #83
What is the size and type of quick connect fitting for a 5740 . I would like to check the pressure . thanks
   / Bump up lift capacity of L3400/LA463 Loader #84
bmiker - Are you asking about the quick connect fittings on the loader or the rear remote? On our L3830 the fittings in the two places are different. I used the rear remote fitting, and according to a parts book at NAPA, it is ISO type, which is larger than the ones on the loader. I didn't have to buy one, since the dealer provided two male connectors to go with the female connectors on the remote.
   / Bump up lift capacity of L3400/LA463 Loader #85
I was pondering an issue. I see there is a pressure relief on the backhoe controls valve and assume there is one on the loader valve so does an increase in the pressure of the main relief vavle have any effect other than the hydro on the tractor itself?
Increase one without increasing the other valves seems a waste of time.
__________________
2006 BX24, Landpride Box Blade
   / Bump up lift capacity of L3400/LA463 Loader #86
It seemed to on mine. I bumped up the main relief valve by about ~200psi and checking the pressure at the loader hookup, it showed the increase. If I'm correct that is past the point of the loader valve.
   / Bump up lift capacity of L3400/LA463 Loader #87
__________________
Kubota loader valves typically don't have relief valves in them. They rely on the system relief ONLY. The BH's may be powered from a PTO pump, so the controls DO contain a relief.
If you have a BH and want to bump pressures, you DO have to coordinate the change with both system and BH relief.
   / Bump up lift capacity of L3400/LA463 Loader #88
I have a hoe on my L3400 - does upping the pressure in the main relief valve (which i've read affects the loader and 3pt.) affect the pressure the hoe will see as well? It appears that it's plumbed into the same area etc.
Josh
   / Bump up lift capacity of L3400/LA463 Loader #89
The BH probably has it's own pressure relief valve. If that is set lower than the system valve, it will pop and bleed off pressure, giving a nominal improvement. It it is set higher than the new system pressure, it will give a nice improvement.
The cylinders on the small tractor BH's are pretty well under engineered. (IMHO) and you may suffer a bent rod. Your call, but I would be leery of it given the fragility of the hoes.
jb
   / Bump up lift capacity of L3400/LA463 Loader #90
On a BX the backhoe is run on power beyond but I thought I saw a relief valve on both the loader valve and backhoe control valves. I dont know if they relieve the increase you make at the main valve though.
PALLET TOTE OF MISC PARTS (A58374)
PALLET TOTE OF...
2007 FORD F-150XL TRITON TRUCK (A51406)
2007 FORD F-150XL...
Hydraulic Tilt Bucket Mini Skid Steer Attachment (A56857)
Hydraulic Tilt...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2013 Ford F-150 Pickup Truck (A56858)
2013 Ford F-150...
26ft x 42ft Double Garage All Metal Building (New/Unused) (A59225)
26ft x 42ft Double...
