Grading Bulldozing With A Box Blade
/ Bulldozing With A Box Blade #21
glennmac - I don't think the physics lesson was so much missed as it was stated in different terms. The reason some tractors top links, or top link brackets, bite the green weenie when bulldozing backwards is because it's not designed for the stress in the opposite direction. And the reason it's more likely to happen to the side links, or side link supporting hardware, is because they're designed for tension stress, and not compression stress. In particular, I'm pretty sure the side link sway adjusters are not designed to handle nearly as much compression force as they are stress force.
/ Bulldozing With A Box Blade #22
Dealing with the stresses as pure compression or tension doesn't reflect the reality of the situation. The blade is almost 100% likely to strike an object off-center, so the loading will be asymmetric. You are therefore probably better off considering the loading on the 3pt as a lateral bending stress or a torsion.
My guess is that on a compact tractor you would have to have fairly significant speed to get enough travel up or down on the links to bend them. I'm betting it's the lateral motion or torsion that sets the process in motion.
Patrick (not patrickg)
/ Bulldozing With A Box Blade #23
Patrick - I agree 100%. That makes a lot of sense to me, too. I think that's why I bent more left-side sway adjusters than right-side ones. The right end of the blade was frequently slanted forward and tilted down a bit when I was grading roads, so it would be the most likely part to hit something really solid and that would put tremendous compression pressure on the left side, as well as tension pressure on the right side. The adusters were better able to cope with the tension pressure, as could be predicted by looking at them.
/ Bulldozing With A Box Blade #24
I too have used my box blade in reverse for bulldozing... I find that it is able to cut <font color=red>much</font color=red> better in that direction! I was recently (before all the rain!) doing some terracing and this was the method that worked best (by far!). However, in terracing, you are constantly pushing harder on one side of the blade. So far (knock on wood) I haven't had any problems. I do take it nice and easy tho...
/ Bulldozing With A Box Blade #25
Harv, I had to fix a bent lower link just last week from bulldozing in reverse. I ended up going to a machine shop that had a 12 ton press because my 4 ton would not straighten the link. While I was being charged $53.00 the machinist gave me a little lesson. He said take a straw and pull on both ends, now take the straw and push toward the center. Well I guessed what he meant and I won't be bulldozing unless I have to. By the way, a new link cost $94 at my dealer. sorry no pictures
/ Bulldozing With A Box Blade #26
Harv, unless one modifies a swing back type to have a lockable back then the only way it can be used for leveling is to be pushed backwards with the rear tilted up so that the inner blades is being pushed backwards. This is the same as tilting a standard box up in the front so that the inner blade is lifted clear of the ground and the box then rides on the rear blade. At least for me that is the case it seems.
I know there are many here who have far more experience with tractors than I ever will--nonetheless---I will continue to both bulldoze and level in reverse. It has had no delatarious effects upon the little BX, surely your big manly tractors can take a little bulldozing. It also seems the 2410 does well so maybe some of you guys have to large a blade in use. Frankly, the arms and the top link form a triangle. A triangle is one of the strongest structures, also an arch, when under compression loads such as when pushing a box backwards. Torsional loads are likely the culprit as someone mentioned but I think you guys are all tractor weenies treating your tractors like some kinda luxury car or something /w3tcompact/icons/wink.gif /w3tcompact/icons/smile.gif . Hades, bend the crap out of it and then buy another arm, If I bend one the next one will be homemade and the tractor will bend first--oops--broken in half Kubotas--here we go.
The boxblade is a mysterious device but clearly it was designed for both forward and backward use unless you think the blade on the rear is just a convienient spare holder or something /w3tcompact/icons/wink.gif .
J
/ Bulldozing With A Box Blade #27
Harv, Let me add one or two bits of info to my previous post about reverse grading. I am going slowwwwww. 1st gear is necessary to give you adequate time to keep the blade adjusted. Yes you do sometimes run against objects. you HIT objects when going unreasonably fast for the situation. I feel sure it is easier to damage a compact or ag tractor in reverse than going forward, but the difference in quality of work offsets the miniscule chance of damage, considering the ultra slow speeds used. I also have the square adjusters as MarkC mentioned. Also the use of the bottom hole for the toplink at the tractor seems to give the tractor more leverage as opposed to the opposite, reducing wheelspin and increasing ability to pust objects. Maybe I am doing something wrong but my long terms results prove otherwise, at least to me.
Common sense should always dictate strategies......
Greg H
/ Bulldozing With A Box Blade #28
Re: <font color=blue>the arms and the top link form a triangle</font color=blue>
They do - but when you consider the extension of any two of the link anchor points on the tractor to the corresponding attachment points on the implement you are dealing with three quadrilaterals. These aren't as inherently rigid as the triangle - hence you will more likely get failure.
Patrick
/ Bulldozing With A Box Blade #29
<font color=blue>He said take a straw and pull on both ends, now take the straw and push toward the center</font color=blue>
That's a good illustration, but you need to be careful with it. Don't forget that for every action there is an equal and opposite reaction. Therefore, unless your implement is magically perfectly loaded in tension, there will always be compression on the links too ...
Patrick
<font color=blue>A triangle is one of the strongest structures</font color=blue>
Well, yes it is. It is strong because it is totally rigid, good for making geodesic domes and cranes and anything else you absolutely do not want bend or change shape. If our 3-pt was truly a triangle, though, we would have a helluva time doing any lifting with it.
Like Patrick says, it's more of a quadrilateral. The top link is distinctly higher than the lift arms at both ends, so there are effectively 4 "sides" to our structure. In addition, the implement's top link connection is designed to be "sloppy", so we hardly have a rigid setup.
All that being said, J, I pretty much agree with the general thrust of your message. These are rugged beasts for doing rugged work. I think the key here, though, is that even rugged beasts have limits, and they'll last longer if we stay within them. The trick, of course, is to discover what those limits are before[/b] we bust something.
/ Bulldozing With A Box Blade #31
Harv,
Not sure if I'm the one Bird is refering to or not, but I did have a post a while back titled <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showthreaded.pl?Cat=&Board=jdown&Number=78484&Search=true&Forum=All_Forums&Words=CVHoss&Match=Username&Searchpage=3&Limit=25&Old=allposts&Main=78484>Tree Stump--1, Draft Link--0</A>
Here's the <A target="_blank" HREF=http://www.kansascas.com/images/tractor/MVC-242F.jpg>photo</A> from it.
Hoss
/ Bulldozing With A Box Blade #32
Its so much fun reading and learning here on TBN. Although I have not done much "bulldozing" with a blade or box I have bent the anti-sway bars while backing the rotary mower into brush. Many times learn the hard way /w3tcompact/icons/frown.gif.
The anti-sway bars (is that the proper term for them?) on the TC40D are tube style "pin in a hole" type. In my ignorant haste when hooking up implements I would put the pin in whatever hole was easiest without taking into consideration the tension vs compression forces, hence my bent anti-sway bar scenario. After that one time straightening the bars (a project of its own) the bars have not bent again despite repeated blows backing implements into stationary objects.
Question: Is there a way to adjust the anti-sway bars to insure that before one bar takes compression the opposing bar will take tension. It seems logical to my challenged mind that if I were boxblading like MarkC mentioned and expected that force to take place on a particular side the anti-sway bars could be adjusted accordingly.
For example: if we are box blading in reverse and expect to hit immovable objects on the right side this would apply force to push the box to the right. If the left arm is adjusted to take the tension force just before the right arm then all is well, left arm takes tension just before the right arm could take compression thus saving the right arm from bending. But if we were to hit an object on the left side, with the arms in the same adjustment, then the right arm would not take the tension before the left took compression. This is what happened to my poor bent arm.
Is there anything I can do besides try to make sure that both arms take equal compression/tension at the same time (Thus avoiding the travel necessary to bend)? Am I off my rocker? (Ok, I already know the answer to that /w3tcompact/icons/wink.gif) How do y'all deal with this?
/ Bulldozing With A Box Blade #33
That's the one, Hoss. Sorry for my poor memory, and thanks for refreshing it.
/ Bulldozing With A Box Blade #34
DVerbarg - <font color=blue>Question: Is there a way to adjust the anti-sway bars to insure that before one bar takes compression the opposing bar will take tension.</font color=blue>
That's a good question. I think that if you make absolute certain that there's no more sway in the whole implement than the amount of play allowed by the movement of a clevis on the end of the turnbuckle rod from horizontal to vertical, you won't ever get compression on the "loose" side. I think that's the secret to keeping from mangling the threaded rods - keeping total sway to 1.5" or so, or less. But I'm thinking about the L-series clevises, too - the smaller the 3-point hitch parts, the less sway you can allow before you have a problem.
/ Bulldozing With A Box Blade #35
There's not too much you can do about the forces that cause the bending - they're inherent in the design of the 3 point hitch. Let's face it - for the range of implements used on one of these hitches there had to be some compromises!
All the instruction I've ever received was to leave the check chains loose with a plow - take the slop out, but leave loose for a sub-soiler or harrow - and tighten them up for everything else. This is the same advice that Kubota gives in their manuals and makes sense when you think it through.
The other thing you want to remember is that you don't want those links to be too strong. If they are then the weak point becomes the tractor - that's not a good thing. Much better to replace the links than have a major repair on your hands.
Really it comes down to old fashioned care and attention when you're dealing with a compromised design like the 3pt ... I doubt I'll ever have to replace any on my BX, but I would expect to on a larger tractor.
Patrick
/ Bulldozing With A Box Blade #36
I reverse doze alot so far had no problems is it LUCK or the LP quick hicth that might keep stress more equall on 3 points???
/ Bulldozing With A Box Blade #37
I reverse doze with my boxblade all the time. Last week I was backing down a hill and bottomed out at the bottom. It bent my left link on my three point. Kubota wanted $59 for a new one, but a two pound hammer and anvil straightened it out fine.
Thanks for the link, Hoss. I had skimmed through that thread as it was posted, but now I've gone back and read it more carefully. Sorry 'bout your link arms, but we're accumulating a real collection of both good and bad experiences here.
Not sure I've reached a real conclusion on the matter, but my crystal ball says I'm gonna try reverse bulldozing sooner or later, and whatever happens, I can't say I wasn't warned.
/ Bulldozing With A Box Blade #39
<font color=blue>…I'm gonna try reverse bulldozing sooner or later, and whatever happens,…</font color=blue>
First to me, “bulldozing“ denotes major ramming, heavy duty “balls-to-the-wall” stress, taking direct aim at that left over tree stump and ….wham…it’s gone…/w3tcompact/icons/shocked.gif
That- I don’t do in reverse… however... being squared off, I will push snow, gravel, debris, spent/downed trees, etc. {mostly all moveable items}…
The times when I’ve seen the most trouble/damage on tractors is hitting something “offset”, diagonally, lateral sideways, or catching a “fixed” object {non-moveable} on the end of the moldboard… {bent/twisted/broken lift arms/top link/3-pt hitch A-frame… and worst case scenario… shattered tractor rear castings… “A man has gots to know his limitations…” Dirty Harry}/w3tcompact/icons/crazy.gif
For best results, in reverse… be squared off and go head on, keeping the bulk of your intended moveable object near the middle of the moldboard/boxblade…/w3tcompact/icons/smile.gif
The same method is used going forward with a loader… sometimes a newbie will “turn” the bucket to give sideways pressure and later wonder how their hefty lift arms got distorted/bent, leaky troublesome cylinders and welds break… on such massive steel…/w3tcompact/icons/frown.gif
<font color=blue>“bulldozing“ denotes major ramming, heavy duty “balls-to-the-wall” stress, taking direct aim at that left over tree stump and ….wham…it’s gone…</font color=blue>
Yikes!!! Clearly I should have said "heifer-dozing".
Fact is, I was thinking more of cases like that walking path that I couldn't quite get a mirror finish on. I did the best I could using the box blade in the forward direction, but between the normal 3-pt "floating" and that silly hinged rear blade (no lock available), I had to settle with merely <A target="_blank" HREF=http://www.tractorbynet.com/forumfiles/5-60412-WalkingPath.jpg>"good enough"</A>.
I guess now I'm just curious to see what kind of results I could get by pushing the box backwards.
Cattle Feeder (A65640)
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
2019 Lynco Mini Mover Aircraft Tug Cart (A61567)
2019 Lynco Mini...
2000 Ford Windstar Van (A64557)
2000 Ford Windstar...
2020 International HX620 Quint Dump (A62613)
2020 International...
