Bukect level idea
/ Bukect level idea #31
The tape and blue pins work fine when scaping with the bucket on the ground. I'm having problems when I have my forks in the bucket and raised up 2-3'.
I have to stand to see the forks over the bucket to check for level.
I'm thinking a pendulum hanging off the side of the kubota level bar that I can see is lined up with the back support of the level indicator.
/ Bukect level idea #32
Another idea:
Get the mercury switch from an old thermostat (or car trunk/hood light switch)with an LED light. You can use a magnet to attach it to your bucket, forks, etc, this would allow you to rotate it so that the light comes on when the attachment is level.
Many electronics stores have small project boxes that would work well. If you use a rare earth magnet and rubber backing there shouldn't be any problem with it falling off. The only downside to this is that if the light is off it won't tell you if you need to curl up or down.
If movement was a problem (vibrations while grading rough ground) then the box could have a mounting hole through it that fits over a pin on the side of the bucket bracket - you could still rotate the device for zero.
2017 CHEVROLET SILVERADO 2500HD (A58214)
2017 CHEVROLET...
2005 John Deere 7420 (A60462)
2005 John Deere...
1999 8ft. Tampa Trailers S/A Utility Trailer (A59231)
1999 8ft. Tampa...
2020 Vermeer Vac-Tron LP873SDT T/A Vacuum Trailer (A59228)
2020 Vermeer...
2018 Ford F-150 Ext. Cab Pickup Truck (A59230)
2018 Ford F-150...
2018 Nissan Sentra Sedan (A59231)
2018 Nissan Sentra...
