Built Canopy for the L3560
/ Built Canopy for the L3560 #11
Mine has something like celotex between the frame and the canopy cover.
/ Built Canopy for the L3560 #12
I'm wondering if the tractor is noisier now than it was without the canopy? My quad is significantly louder with a wind faring than without.
Nice build by the way. I like it.
/ Built Canopy for the L3560 #13
Insulation will help there too.
That other thread must have got you going. :) Nice job on the top!
I haven't noticed any increase in noise. I was on it 2 hrs this morning and it was the same noise level as usual.
/ Built Canopy for the L3560 #15
In regards to the braces....It's hard to see in the picture but there are two braces 3" wide running along both side of the rops horizontal. The u bolts are bolted over the rops , into both braces and run out the top of the canopy. The braces alone without the ubolts fit so tight on the rops that it would take a sledge to get it off. I initially was gonna weld some angled braces after the install but I didn't feel it was needed.
Apparently you understood the need for supports of some kind in that axis and took care of it. You are right, I can't see the braces in the picture but the whole rig looks VERY well made and should make work a lot more comfortable.
/ Built Canopy for the L3560 #17
Jeff said: If you install foam insulation between the roof and supporting frame you will enjoy a significant decrease in temperature in the seat. Conduction, convection and radiation will each be reduced.
Jeff366 - I disagree. There are several reasons why. 1) The orange aluminum top surface amounts to a heat shield from the radiation onto it. It is also several square feet of radiator up there in the air. The air is significantly lower temp than the piece of metal in direct sunshine. There is good air flow on BOTH top and bottom of the large surface. Wide open. Therefore, most of the heat will be lost to the air. I understand heat transfer quite well, though I did not love my courses in thermodynamics. 2) The steel involved is very solidly connected to the ROPS which is very solidly connected to the tractor frame. That amounts to a large conducting heat sink and the temperature of the steel frame will stabilize to the same temp as the ROPS within a few degrees. Any significant heat in that frame will be conducted through the steel. 3) The large surface of the aluminum top will be the hottest thing in the picture and that completely dwarfs the radiating surface of the steel frame. Around 100 to 1. For that reason alone it will not matter at all whether the aluminum is insulated from the steel. 4) Even if those things were not factors (which they certainly are) the driver will never feel heat radiation from that steel frame. There is a large insulator of air between him and the steel frame and the air is moving and dissipating heat all the time from the frame. No driver will ever feel even noticeable, much less significant, heat from that frame. Completely negligible in my opinion. Sorry if I'm too wordy about it.
Kivel trailer mover attachment (A61567)
Kivel trailer...
2025 Polaris Ranger XP1000 (A60462)
2025 Polaris...
2010 Kubota M108S (A60462)
2010 Kubota M108S...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
(INOP) VOLVO A30D OFFROAD DUMP TRUCK (A60429)
(INOP) VOLVO A30D...
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
