Building Lake Corona
   / Building Lake Corona #1,201
How are you going to compact the soil? The very worse machine for that will be something with tracks. For my place, I use my backhoe with a full load of dirt in the front bucket and go over each layer with the tires. My dozer weighs 40,000 pounds and after spreading dirt with it, the tires of my tractor will sink an inch or two when compacting it.
Trying to locate a vibratory padfoot roller to rent for the CTL. Hard to find. I've found one at a rental yard about an hour away. Waiting for the manager to call back and let me know if he will rent it to me. Was told I am outside of their service area.
   / Building Lake Corona #1,204
They will rent the padfoot roller to me, just won't deliver to my location so that is the plan.
Good luck! I will be curious to hear how this works out for you. I'm on the fence about buying one to use on a few projects here.
Do you have a compaction plan in terms of how you will decide that a lift has been compacted enough? (And what is your plane for the lift height?)
All the best,
Peter
All the best,
Peter
The one I am renting is an 84" Bradco. My plan is the bull in a China shop approach. Pushed dirt for about an hour today. Just eyeballing it. Trying to keep the first lift at about 6 to 8" before compacting. This is kind of a hail Mary approach to see if I can make it work. I really only have the one hillside to pull dirt from, no way to get trucks in with clay, so hopefully there is enough clay content in the dirt and the combo of cover, compaction, and adding bentonite will be enough.
I've only been working an hour or two here and there do to being busy at work. Jumped on the loader again this morning for an hour and made a cut into and down the hillside I'm hoping to pull clay from. I wanted to see what the dirt before removing trees around the top of the hill and all of the topsoil. No use doing that if there wasn't usable dirt. So far what I'm seeing looks good.
Getting into some of what my un-trained eye says looks good about 4 feet under the topsoil. Pretty smooth on the cuts with the bucket and not seeing a lot of sand mixed in. Regardless of good or bad this is the dirt I have to work with.
   / Building Lake Corona #1,209
It looks good to me. Keep in mind there is a moisture content of the soil that gives the best compaction. My guess would be that’s to wet but hard to say.
Not seeing any signs of excess moisture at the moment anyway. Grading out well and packing tight under the weight of the tracks without gumming them up. Everything is rolling off the bucket fairly well. Undercarriage is staying clean while working.
2021 BOBCAT S66R SERIES SKID STEER (A60429)
2021 BOBCAT S66R...
TANK MANIFOLD (A55745)
2025 MMS MS36C (A53317)
2025 MMS MS36C...
2016 AutoHauler CX11HCSD T/A Car Hauler Trailer (A56858)
2016 AutoHauler...
2003 McCormick XTX 185 XtraSpeed Tractor (A56438)
2003 McCormick XTX...
2017 Kubota M7-151 Premium MFWD Tractor (A56438)
2017 Kubota M7-151...
