Building a top link holder (when not in use)
   / Building a top link holder (when not in use) #1
shady1701
I was wondering how different makes hold there top link up when you don't use it my tractor has 2 holes not sure how they expect to hold it so i'm going to make one. Any ideas? pics?
   / Building a top link holder (when not in use) #2
Here's a drawing from JD parts for my JD790. It's a hook connected to a bracket (items 1 & 3)
   / Building a top link holder (when not in use) #3
My bota also has a hook.
Steve
   / Building a top link holder (when not in use) #4
Here a pix.
   / Building a top link holder (when not in use) #5
I use a heavy duty bungee cord stretched between the two lift arms, where the lift links attach at the top, it ain't perfect but beats letting it dangle.
   / Building a top link holder (when not in use) #6
My L3130 has a kinda cheesy hook. After adding an HTL I use a rubber strap to hold it up.
   / Building a top link holder (when not in use) #7
On my old ford 8n, there wasn't anything.. I just use a rubber bungy cord.
On my Nh 1920, there is a rod with a hook on it coming out roughly directly behind the seat.. the toplink 'clicks' into there when not in use.
Soundguy
   / Building a top link holder (when not in use) #8
I need to build a new top link holder for my TC30. I added a toolbox to my tractor and its location makes the top link holder unuseable. I need to extend it or mount it in a different location.
In the attached photo you can see the test fitting of the box and the top link holder is the wire rod you can see just below the toolbox. (yes, the brackets got cut down to size)
   / Building a top link holder (when not in use) #9
I've seen an S-shaped piece on Deeres that is there just for that purpose. the base of the S is attached to the tractor horizontally so that it can pivot down when not in use. When the S is pivoted so that it's parallel to the ground the top link hooks into the outer loop of the S. That opening is designed so that the link is held there until intentionally removed. It's simple and effective like most good designs.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2015 Toro Sand Pro 5040 Bunker Rake (A59228)
2015 Toro Sand Pro...
