Building a stick frame house in the woods in 90 days
   / Building a stick frame house in the woods in 90 days #721
Pete,
If you are really putting the sun room in a separate zone you might consider having the contractor put some insulation on those 2 small interior walls around it.
Also, it is probably his standard practice on an upscale house, but you might find out if he is going to put some insulation in the wall between the kitchen and mud room, as well as in the walls surrounding the guest bathroom, for noise isolation control...
I vote yes for the skylight. If she wants to raise flowers in there it will be a big plus, or wants to view the activity in the sky on a cold winter night w/o freezing on the deck. If it leaks or blows off, fix it, as you would any other part of the package.
   / Building a stick frame house in the woods in 90 days #722
Right, the builder told me that when I asked about spraying the basement ceilings, so we plan to not do that, although I do want the holes sealed where the 2x12 boards for the deck protude and I can see daylight.
Pete:
When I worked at NREL National Renewable Energy Laboratory (NREL) Home Page we designed in-house a 2,500 square foot laboratory for the scientists working on top of the mesa overlooking the main campus. One of the things the ES & H (Enviromental Safety & Health) group made us consider was doing our best to seal up the building from mice due to the possibility of Hanta Virus carried by deermice. We learned that mice can get into a building through a hole as small as a 1/4". Around our house, I have stuffed up possible entry points with stainless steel sponges/scouring pads I got from MSC Direct. The sponges cut easily with scissors, go a long way, don't rust, and the little buggers can't chew through them.
Scrubbers - Sponges & Scouring Pads | MSCDirect.com
Seal up the holes now, not later.
Pete, a couple of items come to mind here.
3) Don't know if you'll have this issue but my master bath is located next to an exterior wall. One time when it was very cold outside I noticed some drips coming from the exhaust fan located in the ceiling. This occurred (I think) because the area above the bathroom is an area without heat. The vent pipe (like you showed coming from the master bath) just sat on top of the insulation. What I did was wrap the vent pipe with several layers of insulation to prevent the cold glass syndrome. My suggestion to you is have the spray insulation guys give a shot of the foam surrounding your vent pipe. You could then later wrap/cover the pipe for added protection or tell the insulation guys to wrap the pipe with some batts.
Stanley
Our Master Bathroom has the mirrors on the outside walls, and even with minimal code required insulation (fiberglass batts); the blasted things get condensation on them. If your Master Bathroom has mirrors on the outside wall; look into getting the electric heaters that go behind the mirrors to keep the condesation at bay. Heck, you might look into towel warmers too. A buddy has them in a house and he says they are great. I have no experience with them.
Pete,
All the above to get back to your humidity comfort statement..........
We have an aquarium with a waterfall pump, a large statuary fountain thing in the flower room to keep the orchids happy between watering, take 2-3 showers a day and have 2 bodies adding moisture to the air. We still need to run the humidifier to be comfortable at 72 degees inside and not hack and cough in the morning.
Your mom is only 1 person so she will not generate as much moisture.
At your house you have big fish tanks and big filter troughs in the basement that are bound to be adding humidity to your inside environment plus a wife and kids.
You will have to be the judge, but if he has to modify the trunk lines on the HVAC for fresh air and humidification, now would be the time to do it, as well as getting the programming set right for the system, rather than adding this stuff later and hoping it can be made to work properly.
We have an Aprilaire bypass humidifier and I've seen rebadged units from Carrier, Trane, and others offered. In our dry climate, a humidifier is a good thing to have; but this Aprilaire has been a PITA with water leaks, water hammer when the solenoid valve shuts off, condensation on the windows, etc. Don't get me wrong, it helps moisten the air; but I have to think there must be a better solution out there than what is essentially a mini swamp cooler. Don't get any of the units that look like a paddle wheel that mounts to the underside of the duct as these rely on a sump of water for the paddle wheel to rotate through and pull water into the airstream to vaporize. The sump can be a breeding ground for microbial nasties. I've heard of steam humidifiers; but haven't investigated them.
Kinda a scaled down version of my system in the basement, which looks like this:
That's quite a system!
I believe the garage doors will be R9 and the walls, being 2x6 with the same ~1.5" blow foam and the batts, will be the same as the rest of the house. Thinking about it some more, I feel not worrying about running HVAC duct's the the garage makes the most sense. The garage should stay "temperate" I think.
I would think the garage should stay temperate in all but the most frigid of temps as you're insulating it. Another reason I wouldn't run ducts from the living space to the garage is that code may require you to install automatic fire dampers, and that could get pricey. If the garage needs heat, add a separate heat source of some kind. Just remember, no matter how well insulated the garage doors are, they still need to seal well to keep overly hot and cold air out.
With all the talk about insulation that has gone on in this house, isn't it counter productive to put in skylights? I don't know of anything quite as bad for loss of energy then a big hole in the ceiling with no insulating properties. At least with windows, most of the energy is going up and held in place by the insulation in the attic, but when you put in a skylight, that just creates an open path for heat to leave or enter the house almost unrestricted.
While the light is nice, what you lose in energy, it's a lot cheaper to run a light all the time.
I've also found that there isn't any such thing as a skylight that doesn't leak. It's just a matter of when. You might get lucky and get 20 years out of it, but there are a lot of people out there who didn't get half that out of theirs. I know it's always blamed on the installation, but just the way they are designed leads them to failure over time. The more severe the environment, the sooner they fail.
Eddie
I like the concept of skylights; but I agree with Eddie on this one as I think they are more pain than they are worth. Although you're planning on skylights for the kitchen area I believe; you might want to look into various forms of light control (e.g. blinds, shades, etc) in case too much of a good thing (aka sunlight) pours into the kitchen, and how easy it will be for your Mom to operate the shades. If you go with skylights, research them and find a good brand.
I had envisioned a glass double door there and making an excellent natural light studio.
The double doors in the basement are being replaced with ones that have glass in the top half. That was the plan all along, but there was a misunderstanding somewhere along the way. All glass doors are perhaps not a bad idea. Will discuss with mom and also find out how close the glass top doors are from being delivered.
Very nice. How much power do you have running to there?
2 30A 240v circuits for the 3kw UPS units, a 20A 120V circuit for the 2.2kw UPS and a 20A circit for the sub amps.
I have a pair of large skylights in my house and they have never given me any problems. My house was built in 1997.
And yes, the sunroom is isolated from the rest of the house via the 5' sliding glass door (low E exterior door). Excellent idea about putting insulation in the interior walls in the sunroom, and also in the wall between the kitchen and mudroom, and bathrooms. I'll make sure they do that.
No skylights planned for the kitchen. I'll discuss skylight brands with the builder for the sunroom and make sure they are low E Energy Star rated like all the other windows. The will be relatively small, fitting between the 16" oc of the trusses.
After hearing everyone's thoughts on heat in the garage, I agree that just insulating it will be sufficient. There will be plenty of lights in there however.
   / Building a stick frame house in the woods in 90 days #726
I've got skylights in 2 properties. One is a very well insulated house that is largely glass on one side (wall of sliders). Its amazing the difference between high and low end skylights. The low end ones at one property get condensation and drip, the high end ones don't drip or even fog. Thats one area where money is well spent. I agree that they will eventually leak!
   / Building a stick frame house in the woods in 90 days #727
You cant run house HVAC to the garage. Its against code nearly everywhere due to car exhaust. I am not sure of anyone said this yet but don't do it. What you CAN do however is run a new gas line to garage from you gas source. Seal up the pipe entry point with red fire barrier caulk or foam. You can add whatever heating source you want in the garage, but the wall mount is the easiest and cheapest option. You CAN however have a seperate HVAC ducts that doesnt connect to the house in the garage as long the heater is in the garage if you want.
   / Building a stick frame house in the woods in 90 days #728
Pete - Glad you are making the change to duct work to the garage. My sister's house had it and when she had an energy inspection by the electric company they stated that even though the ducts were closed the heated/cold air in the duct lines were causing an imbalance to the other ducts in the house. They disconnected them at the main branch and she noticed a big difference in the house. They also mentioned the fire problem and blocked the ducts permanently in the garage. During their inspection they found that the taping of the duct work in the attic was already separating and had to be retaped to prevent loss air flow. Just my 2「.
   / Building a stick frame house in the woods in 90 days #729
my 28ft by 36 ft garage that attaches on the 36 ft side has never gone below freezing and has no additional head, even in coldest weather stays about 42 deg.
   / Building a stick frame house in the woods in 90 days #730
Even a glass sliding door to match the main floor ones would look fine, if you don't anticipate needing the full width of both to move stuff in and out. Even then both panels can be quickly removed for that rare occasion. Protecting the slider threshhold from stones is important, but you will probably have a paved entrance pad in front of the door. That and beds of shade loving beautiful impatiens growing under the window and wall area will really make that area come alive.
2003 Freightliner FL60 American LaFrance Ambulance (A56858)
2003 Freightliner...
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
CAT 336E (A58214)
CAT 336E (A58214)
2005 Sterling Acterra Tender Truck (A56435)
2005 Sterling...
2007 Homemade Pipe Trailer (A55973)
2007 Homemade Pipe...
2016 Chevy Tahoe (A56859)
2016 Chevy Tahoe...
