Building a powered sweeper
/ Building a powered sweeper
give us a shout whaen you get all your pc set up - i really would like to see this - it sounds pretty mean
when youve got it all set up what are you planning to use it for?
keep me posted cheers mith
/ Building a powered sweeper #12
Check out Steiner's I've got one on order.
Thanks - i found it but i cant see nor does it say whether it is powered by the wheels or by a PTO, can you tell me?
im looking for a powered one as the wheel pwoered ones soak up HP on my slopes cheers
mith
thats just what i want - but a tad pricey no? so any ideas how to build one
mith
/ Building a powered sweeper #16
Get an old silo filler and turn it sideways. It should work direct no belts. bcs
wow wow wow slow down - silo filler? how does it work? where do i get one from? con i get one in the UK? run off tractor? size?
cheers mith
/ Building a powered sweeper #18
What about starting with a used rear mount tiller. Take off the worn out tines and shaft, replace with a brush. Then build a dump bin. May have to change ratios to get the speed right. Will need gauge wheels & may have to convert to pull type.
hey nice idea i thinking thats a goodun
hadnt thought of that and thats sounding easier that my idea - yeaaaa
but the tine rotate the wrong way dount they and how fast do they rotate/need to rotate? any ides how to fix this?
thanks man
mith
/ Building a powered sweeper #20
I could be wrong but some gear boxes are built so that the gear for the output shaft can be removed and put back in on the other side of the box. Other than that, the gear box may be able to be turned to the other side of the tiller. If the splines on the input and output shaft are the same, looking down at the top of the gear box just rotate it 90 degrees and move all the driven stuff to the other side. Depending on the diameter of the brush the speed may be OK. I have a 38" craftsman wheel driven sweeper. It does have a few flaws but generally works very good.
2461 (A58376)
2461 (A58376)
2002 Ford E-450 Enclosed Service Van (A59230)
2002 Ford E-450...
CHANDLER 500 BBL FRAC TANK (A60736)
CHANDLER 500 BBL...
2011 Mercedes Benz GL AWD SUV (A59231)
2011 Mercedes Benz...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A60736)
2014 FORREST RIVER...
Rooster Weathervane (A59231)
Rooster...
