building a cab for a kubota
   / building a cab for a kubota #1
case245
Platinum Member
pa
kubota 7040sud
i need to put a cab on my 7040sud kubota im thinking square box tubing for thr framing with snaps glued on the tubing stainless steel snaps how would that work in high winds and what size box tubing to use for main framing i was thinking 1 inch
   / building a cab for a kubota #2
You are wasting all our time. Since its not worth a darn for skidding logs your gonna buy a CaseIH. Remember?
   / building a cab for a kubota #3
Perhaps the kubota is working better now. Adding weight to my M6800 made it pull much better.
   / building a cab for a kubota #4
I think you would be happier if you traded the Kubota for a Case with a cab already installed. A homemade cab is going to ruin your trade in value on that new Kubota.
   / building a cab for a kubota #5
I build one out of 1-1/2 inch angle iron in 5 parts (4 sides and the top), which lets me take it off for the summer quite easily , and put lexan all around with plywood on top. Not the best looking cab around, but it makes a big diff. in the winter. Much cheaper then a newer tractor or a aftermarket cab.
   / building a cab for a kubota #6
you seem to have plenty of money to throw around becuase you buy tractors and run them for less than 100 hours before trading them in on new ones. Why not just trade this one in on another kubota with a cab
   / building a cab for a kubota #7
Because it still wont pull as hard as a 21HP Case. :confused3:
   / building a cab for a kubota #8
ha.......
2019 BOBCAT T870 SKID STEER (A60429)
2019 BOBCAT T870...
International S1900 (A56436)
International...
378721 (A54865)
378721 (A54865)
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
