building a cab for a kubota
   / building a cab for a kubota #1
case245
Platinum Member
pa
kubota 7040sud
i need to put a cab on my 7040sud kubota im thinking square box tubing for thr framing with snaps glued on the tubing stainless steel snaps how would that work in high winds and what size box tubing to use for main framing i was thinking 1 inch
   / building a cab for a kubota #2
You are wasting all our time. Since its not worth a darn for skidding logs your gonna buy a CaseIH. Remember?
   / building a cab for a kubota #3
Perhaps the kubota is working better now. Adding weight to my M6800 made it pull much better.
   / building a cab for a kubota #4
I think you would be happier if you traded the Kubota for a Case with a cab already installed. A homemade cab is going to ruin your trade in value on that new Kubota.
   / building a cab for a kubota #5
I build one out of 1-1/2 inch angle iron in 5 parts (4 sides and the top), which lets me take it off for the summer quite easily , and put lexan all around with plywood on top. Not the best looking cab around, but it makes a big diff. in the winter. Much cheaper then a newer tractor or a aftermarket cab.
   / building a cab for a kubota #6
you seem to have plenty of money to throw around becuase you buy tractors and run them for less than 100 hours before trading them in on new ones. Why not just trade this one in on another kubota with a cab
   / building a cab for a kubota #7
Because it still wont pull as hard as a 21HP Case. :confused3:
   / building a cab for a kubota #8
ha.......
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2019 KENWORTH T680...
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
2022 Brush Wolf 4800X Severe - Duty Excavator / Backhoe Brush Cutter (A57024)
2022 Brush Wolf...
Attention (A57148)
Attention (A57148)
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
