Building a bridge?
   / Building a bridge? #1
BoneDigger
Bronze Member
Tyler, TX
2015 New Holland Workmast 35
I have a small creek I need to build a bridge across. The span is only about 6 ft but I would probably build it out 12 or 15 ft. I was thinking of using 4 x 6 lumber as the main support. I'd put them 2 ft apart and use 6 for a width of 12 ft. Then I'd use 2 x 6 treated for the cross pieces. Would that be strong enough to hold a standard farm tractor (35hp) with attachment? I know it would be fine for my Ranger, just not sure about the tractor. I would of course anchor the bridge as well.
Thoughts? Bad idea?
   / Building a bridge? #2
If you can support both sides of the bridge at the 6' center distance, you should be ok.
If you can only support out at the 12'-15' length....NO!
   / Building a bridge? #4
Look for a old 20' shipping container thats trashed. Should be able to pick it up for nothing. Strip it and use the floor.
or
A old trailer, 5th wheel frame. Same thing with lots of strength.
It's maybe 4 or 5 ft to the bottom. A creek passes under.
So, you would think I would need to add a center support?
   / Building a bridge? #6
A trickle or a torrent?
Thinking a couple of pieces of 24" culvert side by side with your wooden bridge over top using them for support. But if the water has a tendency to get higher and rush, that may not be feasible.
   / Building a bridge? #7
I’d use a junk trailer. You can buy them a lot cheaper than you’ll be able to build a suitable bridge. And a 4x6 on a 24” center isn’t nearly strong enough IMO.
   / Building a bridge? #8
Thoughts? Bad idea?
I went through this a few months back, thinking I needed to move my present tractor crossing which was a PITA in 2018 with the huge amount of rain we had. This year, it has been fine with its 5 or 6 six inch PVC pipes underneath piled up rocks, concrete and packed soil, like so many years before 2018.
If I was to move it downstream, it was to a place where the width was about 6 or 8 feet. I was looking at putting in 5 railroad ties and covering them with 2x6s with fairly wide spacing (2x6s would be perpendicular to the ties, to "tie" them together), just close enough to keep my tractor tires from going through. Got this from talking to other men at church who had built bridges for big tractors to do over.
I was thinking of getting a boom pole for the 3ph to pick the ties up and set them across the opening. I'd set at least one tie on each side of the crossing in parallel with the stream, hopefully recessed a bit so that I wouldn't need a ramp to get upon the 2x6s atop the cross-the-stream ties and all. Could just set a 2x6 there. Could possibly do without the initial ties or 2x6s and join the ties above with the 2x6s across on top. Having those initial ties or 2x6s would just make it easier to move the longer ties to get them positioned properly.
This is the thinking that I went through. Even got a location/business for 12 ft ties.
The old crossing is fine as long as we don't have the deluges to keep dumping silt in and plugging up those 6 inch PVC pipes underneath. Seem to only need a couple working to carry the normal stream flow.
Ralph
   / Building a bridge? #9
If you put in a culvert, be sure you check to see what the watershed area is and the capacity of the culvert to pass the expected runoff. There are charts to determine culvert size. As for bridges, here's an engineered bridge plan:
https://www.fs.fed.us/t-d/pubs/pdfpubs/pdf12232316/pdf12232316dpi300.pdf
   / Building a bridge? #10
Hey, that's an idea. A local Kubota seller sells the tractors with loaders, bush hog on a trailer as a package. I was wondering where I could park the dang trailer. It could go across my stream at a point a little downstream. No trailer licensing, etc.
How the **** do you get the trailer across the stream though? Hot air balloon to hold up the *** end?
Ralph
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
Land Honor Quick Attach Land Plane (A50514)
Land Honor Quick...
2013 FORD F-550 SUPER DUTY XL BUCKET TRUCK (A51243)
2013 FORD F-550...
John Deere Imatch Quick Hitch (A50514)
John Deere Imatch...
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A51242)
2021 CATERPILLAR...
