MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 65,661
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Spent a couple hours playing with a reamer getting the swing pivot to work freely. When I welded up the swing pivot box around that 9" piece of 1" I.D. tubing, the tubing shrank and would not take a 1" bolt/pin. I have a friend that had a very old Craftsman reamer set and it had one that would go from a little less than an inch to a little more than an inch. I had to run it through about a half dozen times to get it to where the pin was free all the way through. It takes about 500 cranks to get it through the 9" tube X 6 trips through the tube = 3000 turns of the wrench! My arms hurt!
But man, it swings sweet now.
The bolt stays in place and the tube rotates around it like it should. I'll probably end up tack welding a lock nut to the bottom of the brackets and that should do it for that assembly. I'm going to add two grease zerks to the tube, then it is just a matter of grinding everything smooth.
I think the unit is 75% complete now, structurally. All but two cylinder brackets are in place and I am now going to concentrate on wheels and outriggers.
Now, some questions about hydraulic controls arise.... I don't know if I want to buy two dedicated loader joystick valves or go with the modular bank of valves. I have to start pricing things out.
Two joysticks will operate the swing, boom, dipper and bucket. Then I'll still need two valves for the outriggers.
A modular valve bank could be ordered with 6 valves and accomplish the same thing, but I would have to purchase two joystick handle kits. I'm set on having joysticks VS independant sticks for each valve. I had a two handle loader valve on my IH and it was a pain. You could do it with the heal of your hand on the outer valve and your thumb and forefinger on the inner valves, but after a few hours it was tiring. The PT425 joystick is very smooth. For that matter, two valve bodies like that on the PT425 would be perfect. They have three spools with the joystick operating two of them and the third could be for an outrigger.
Lots of choices to price out.
Running totals:
Time = 32 hrs.
Approximate Cost = $380
Running totals:
Time = 32 hrs.
