Backhoe Build A Backhoe For PT425... It Could Happen
   / Build A Backhoe For PT425... It Could Happen
Started welding tonight. I wanted to wait until I had all the pieces cut before starting to weld, but realized that would be impossible, since I am not strictly following the plans. I needed to weld the first piece on the frame so that I can measure, cut, drill and weld the two brackets that will hold the top and bottom of the boom pivot assembly.
So, here's a couple pictures of the first two pieces going together.
1st one is a side view of the main frame tipped on its side. It is 48" long. The piece I welded on is about 6" long.
2nd picture is of the 6" piece welded onto the top front of the main frame rail.
Last one for tonight is an end view of the front of the main frame rail with the 6" piece on top. This is the proper orientation to the ground as it will be when finished. It started to rain AGAIN!!! 9 days straight with rain. Maybe I'll get it finished in time to dig a moat around my house. /forums/images/graemlins/tongue.gif
   / Build A Backhoe For PT425... It Could Happen #216
Lookin good there MR ...... your the man.... /forums/images/graemlins/cool.gif
   / Build A Backhoe For PT425... It Could Happen #217
Went to the storage shed today and picked up my last piece of 4X4 tubing. Also brought home a sheet of 1/2" diamond plate about 2' x 4'. Pieces of that will be used for making my brackets and tabs for cylinder mounting and the boom swivel holders. I'll rough them out with the torch and finish them up on the band saw and grinder. I also found a piece of 1/8" diamond plate about 6' x 14". That will be my floor plating.
I currently have about 2 hours of actual labor into it. The rest has been driving, hauling, planning, waiting for the saw and such. /forums/images/graemlins/tongue.gif
   / Build A Backhoe For PT425... It Could Happen #220
are you using a mig torch to cut the metal with, or a plasma cutter? Just curious, since the only thing I know about welding is not to stare into the bright light...
Ford 655C 2WD Cab Backhoe (A56435)
Ford 655C 2WD Cab...
2008 BMW 535xi AWD Sedan (A56859)
2008 BMW 535xi AWD...
2004 DITCH WITCH 3700 RIDE ON TRENCHER (A52709)
2004 DITCH WITCH...
2019 Ford F-550 (A55973)
2019 Ford F-550...
2005 FORD F-150 XL (A55745)
2005 FORD F-150 XL...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
