Backhoe Build A Backhoe For PT425... It Could Happen
   / Build A Backhoe For PT425... It Could Happen
1st bracket for boom pivot assembly roughed out and resting approximately where it will attach. Still needs 1" hole in the center of the arc for the pivot pin and trimmed to length to fit over the 6" piece of 4X4 tubing. (top view)
Side view of bracket.
First bracket took about 15 minutes to cut out with band saw. Started to rain, so I stopped for the night.
About 4.25 hours so far.
Finished roughing out the second bracket and drilled the 1" holes in them for the main pivot pin. Here they are resting where they will be welded to the main frame after they get some 1"ID x 1.5"OD tubing welded on the outsides for the pivot pin to go into.
Close up of the brackets.
Here's how it's gonna look with the boom attached. Missing from the picture is the box I have to fabricate to hold the pivot tube. The pivot tube box will be pinned through the brackets that I showed in the last picture. The rusty L shaped brackets that hold the boom will be welded to the pivot tube box.
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A56435)
1992 Talbert 70...
2002 Bobcat 763 Compact Skid Steer (A56435)
2002 Bobcat 763...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
2012 Dodge Grand Caravan (A56859)
2012 Dodge Grand...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A55315)
2025 Wacker Neuson...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
