Backhoe Build A Backhoe For PT425... It Could Happen
   / Build A Backhoe For PT425... It Could Happen
1st bracket for boom pivot assembly roughed out and resting approximately where it will attach. Still needs 1" hole in the center of the arc for the pivot pin and trimmed to length to fit over the 6" piece of 4X4 tubing. (top view)
Side view of bracket.
First bracket took about 15 minutes to cut out with band saw. Started to rain, so I stopped for the night.
About 4.25 hours so far.
Finished roughing out the second bracket and drilled the 1" holes in them for the main pivot pin. Here they are resting where they will be welded to the main frame after they get some 1"ID x 1.5"OD tubing welded on the outsides for the pivot pin to go into.
Close up of the brackets.
Here's how it's gonna look with the boom attached. Missing from the picture is the box I have to fabricate to hold the pivot tube. The pivot tube box will be pinned through the brackets that I showed in the last picture. The rusty L shaped brackets that hold the boom will be welded to the pivot tube box.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
TANK MANIFOLD (A58214)
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
23105 (A56859)
23105 (A56859)
