MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 65,662
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Between people stopping by and occasional spits of rain, I was lucky to get 2 hours in today.
I fabricated the bucket linkage, mounted it to the dipper stick, tacked the spacers and bushings in place and checked for articulation. I need to adjust the cross tube that goes through the dipper stick a foot up from the end. It is not quite square and makes for a small bind. I will ream out the bottom of the hole on the side that is too high and keep test fitting until it operates smoothly and is square with the dipper stick before I tack the tube in place.
I also started fabricating the 12" bucket. The plans call for making the bucket from 1/8 inch plate. However, I don't have any. I am using 1/4 triangular plates for the sides that I think will make for a good bucket shape and size. The bottom and back of the bucket will be from 3/8 diamond plated. The smooth side will go inside the bucket and the diamond side will go on the outside.
Pictures will be taken before I continue.
Running totals:
Time = 53 hrs.
Approximate Cost = $1600.00
Running totals:
Time = 53 hrs.
