Buddy clinically dead
/ Buddy clinically dead #31
My next door neighbor recently went through the same type thing. He was pulling a skid steer on a trailer behind his F150. He didn't have it tied down well enough and when he put the brakes on it shifted on the trailer. The weight of it shifting was enough to pick the front end of the truck up and pitch it into a ditch rolling the truck and trailer. He got out OK, but the truck was totaled and then he had to repair the SS he was borrowing.
Hope everything turns out OK for Tim. Prayers sent.
Mike
/ Buddy clinically dead #32
High Compression said:
This is true. If you look close in the pictures, it is a tandem dual 20k gooseneck trailer. It would be difficult to position a backhoe on that trailer so that it didn't have enough tongue weight. He did do a good job chaining it on the trailer though. It sure didn't go anywhere.
I am sorry to here about your friend
What picture are you looking at cause all I see is the backhoe on it's side I looks like the trailer is. Way to short for the load it was hauling and that would make it fish tale with a heavy load
/ Buddy clinically dead #33
I don't think you're correct, Ford used to have a blanket 20,000 lb combined weight rating for all the 250/350's back then. So the lighter trucks could tow more than the heavier dually, but the dually was still going to have more than 11,300 lb rating. No one used this tow rating obviously or 5th wheel trailers and goosenecks wouldn't have sold.
Having worked on and around those 80's trucks, yes they have heavy rear axles, and heavy frames, but the newer max tow rated F150's also have heavy frames and much larger front rotors and big rear discs. Part of the heavy frame section on the F250/350's is due to the long box/crew cab options that have a long frame. To get the bed capacity on a long frame you need a deep section frame. The F150's don't offer a heavy bed capacity.
Lots of old dump trucks had low tow ratings, lots of reasons from poor brakes to weak drivelines but that doesn't mean you need a big dump truck to tow a trailer.
I still think the tow ratings are more of a competition between manufacturers than anything else. Heck, the GCWR of the new F-150's is more than that of a 90's F-350 dually. Park those two trucks side by side, which is a heavier built truck?
Edit: Another example just came to mind. My father has a new Dodge 3500 dually, the tow rating on it is very close to our '75 C60 dump-truck. Had either of those trucks been in the same situation as the OP posted, which would have ended up the same way?
/ Buddy clinically dead #34
Granted it sucks when someone close gets seriously hurt.
But before jumping to conclusions about capacities and capabilities of an entire group of vehicles, Im certainly going to look at a number of key data points associated with the serious accident.
1) what was the speed of the vehicle at the time it crashed (easily obtained from vehicle black box, or smart phone data or onstar data)
2) What was the status of the drivers cell phone at the time of the accident.
3) what other exterior forces may have contributed to the accident. (such as a tire blowing out on the trailer, being cut off, functionality of the brake controller and trailer brakes etc)
Any drawn conclusions about the accident are worthless without solid answers to the above simple questions.
/ Buddy clinically dead #35
While I agree with a lot of what you say, it still doesn't seem right to be pulling as much as people do these days with the trucks they do. To me it's all about having the right tool for the job. It just is a much easier, calmer, and safer towing experience when you have plenty of truck for what you are towing. Same as having a tractor big enough for the implement you are working with. It's more productive to have a well matched pair. Maybe I'm just old school, but 20K trailers are a good combo for most MDT's, where as 10K trailers are a good size for most 3/4 and 1-ton trucks. I'll be real interested to see how the new SAE tow ratings affect the different manufacturers.
/ Buddy clinically dead #36
Thats the most sensible comment on this accident so far. You might hold a grudge against the employer who sent him out, its understandable.. But right ?? cant tell.. It really is horrible to see a friend of yours get hurt, so i principally refrain from guessing for the circumstances, as we simply dont know it. Lets not start a witchhunt before the traffic authorities have investigated it.
At my former employer where we built 5th wheel trailers for light duty trucks, we adopted Knorr EBS braking on all that we built: Air brakes with electronic stability control. We had some dare devils that tested the system with an improperly loaded trailer (just loaded at the back, with a 1500kg tail lift platform) and the EBS system would eliminate all sway by braking left and right intermittently. It even brakes to control a roll in a corner.
One might ask oneself if air brakes, ABS and EBS should be mandatory on over 10k towing. There is an 80% chance that a sway resulting in overturn, would have been prevented by such advanced safety systems.
Sounds like a bad situation all around. Hope everything works out. Seeing as how that is a pintle hitch trailer, I'd have said NO plain and simple to towing that, even if my job depended on it. Did that once with a 14K pintle hitch loaded with a Ditch Witch and it was down right scary. Pintle hitch trailers over 10K are medium duty truck territory, period.
I've long said that loads like that should ONLY be towed by a medium duty truck, but most folks don't listen. They think if the manufacturer says a light duty truck can pull 20K then that's what they'll pull with it. The reason the tow ratings are climbing so high is for no other reason than to sell more trucks. It seems like the only thing they base this on nowadays is power. They want to be better than the other brand, only care about liability enough to make sure it's on the edge of being safe.
Almost as bad are the 1/2 ton trucks rated to tow over 11,000lbs these days. The may have plenty of power and huge brakes, but last time I checked still have very soft springs, relatively light frames, and don't weigh that much. As I said in another thread, my '88 F-250 is only 'rated' to tow something like 7-8K, and it is WAY more truck than those new F-150's.
I'm guilty of sometimes towing more than I should. My father has a 3500 cab-chassis Dodge that we sometimes pull 18k with. It is rated to tow that much, but may not necessarily be safe. I think single tire gooseneck trailers (14k) are about all that a 1-ton pickup should be pulling. To some extent this coincides with the CDL laws as a 14K trailer + 10-11K truck puts you right below CDL requirements. Move up to a tandem dual 20K trailer and IMO you need minimum of a class 4-5 truck. Over 20K is class 6 and up territory.
:thumbsup:
Question: Most of us on TBN have tractors bigger that what we need and yet we always want bigger. Why is it the other way around with the tow equipment? Oh I can pull that with a half ton, oh that's no problem for my one ton. I've been doing it for years that way...:confused::confused2::confused::confused2: I haven't read anyone post, I don't need that M or L series Kubota instead of their BX, cuz they have been doing it that way for years.
/ Buddy clinically dead #39
Not everybody thinks that way.. or thinks that way forever.
I used to pull alot with a half ton. when it was feasable.. I got a ford f450 DRW and a GN trailer, and have now retired the half ton and all but retired the bumper pull trailer.
i hate white knuckling it when heading downt he road especially on a long haul knowing im right at the limit of my vehicle or trailer capabilities.. not fun..
soundguy
/ Buddy clinically dead #40
Because a lot of people think it is 'macho' to see how much their truck can pull. Granted, this wasn't probably the OP's case I'm sure.
I hear it all the time, especially from the type that have stacks on diesel pickups, how much they have pulled, hauled etc. Some of them claim they tow upwards of 30K with 1-ton pickups. Not sure if that is true, but I have seen a few around here hauling backhoes and small dozers. Also saw a guy hauling 14 5x6 round bales on a gooseneck, the hay alone would weigh over 25K. Not sure if it's being macho, cheap, or just ignorant, but I try to steer clear of them.
2020 Bobcat T76 R Series (A60462)
2020 Bobcat T76 R...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
1991 International 4900 Box Truck (A55315)
1991 International...
2006 GENIE S-45 TELESCOPIC BOOM LIFT (A59823)
2006 GENIE S-45...
EXCAVATOR RIPPER (A58214)
EXCAVATOR RIPPER...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
