Bucket tooth spacing?
/ Bucket tooth spacing? #1
countrybumpkin
Elite Member
Kioti, kubota
Looking at a used 72" fel bucket to weld some 23tf teeth on, I've found anywhere from 6 to 9 teeth on 72" buckets. Just wondering what others have on this size bucket? Also anyone tried the twin tiger tooth, I see most are using the standard digging style.
/ Bucket tooth spacing? #2
Don't know anything about the twin tiger teeth nor have I wonder welded any teeth ever on my bucket (tried out a bucket with teeth and with my soil conditions I barely noticed any gains, however backdraging is "lost", something I use my loader for very often).
But basically the less teeth the better the digging force, as the same force is spread on less surface, however, it increases the chances of breaking a tooth or bending the bucket. Also less teeth will "scoop" less. (Compare a cutting edge scooping material vs 3 teeth vs 15, the contact area allows the scooping).
If it is softer soil, the number of teeth wont change anything as the bucket drives into the pile.
I think the ideal composition would be less teeth for more digging ability, or no teeth for most scooping/better level. The "more teeth" is simply a compromise between the two..
Just depends on what you want to use the bucket for.
Ian
/ Bucket tooth spacing? #3
You can count the teeth on my 72" bucket,,,
my toothbar is pretty much perfect,, IMHO.
It is a CAT skidsteer bolt-in toothbar.
/ Bucket tooth spacing? #4
My tooth bar has nine teeth across my 72" bucket.
/ Bucket tooth spacing? #5
8-9 in spacing is about the norm give's you 9. The "tiger" tooth if it is what I'm thinking about is very aggressive tooth, good in shale rock and require's a good heavy machine behind it.
/ Bucket tooth spacing? #6
countrybumpkin, it's been my experience that more teeth are better, new teeth are best. here is a photo of an 84" ctl bucket I had 13 teeth added to along with an additional cutting edge for strength. The cutting edge in the photo (yellow) with 4 teeth welded to it is a bolt on smooth edge so I can use it for snow or street cleanup. I remove the corresponding teeth from their shank on the bucket, slide the smooth edge on, put in bolts. I don't have any experience with tiger teeth. I have seen them on hoe buckets where the digging was UGLY, not where I would want tires. lt190bbolt on smooth edge 006.jpg
/ Bucket tooth spacing? #7
8 teeth on mine I went higher as I use it a lot for grubbing and raking.
/ Bucket tooth spacing? #8
The 72", one cubic yard Bobcat bucket has 8 bolt on teeth.
Ok thanks everyone, 8-9 is what I'll probably go with, I haven't really decided on teeth type still, may just stay with a standard digging tooth.
/ Bucket tooth spacing? #12
What has 12 teeth and 48 legs; ..............................beer line at the county fair.
Ended up picking up the bucket today for 200, now I just need to get the teeth and install them.
2010 Deere 318D (A60462)
2010 Deere 318D...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
2016 John Deer 5075E (A60462)
2016 John Deer...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
Wilmar Wrangler 4500 Loader (A66285)
Wilmar Wrangler...
New/Unused Wolverine 72in Quick Attach Smooth Bucket (A65583)
New/Unused...
