Bucket Side Walls
/ Bucket Side Walls #1
dallasfan458
Chester County, PA
John Deere 955
Recently was pushing large rocks with the front bucket, got off and realized that I had bent in the ends about 2 inches out. I was able to bent them back because the steel is softer than I imagined, has anyone ever reinforced their sides? I was thinking of welding on 1/4 inch thick 3 inch wide bar stock to the inside, wanted to see if anyone has had similar experience. Thanks.
/ Bucket Side Walls #2
If I was going to do something like that I would put them on the outside or they will hold any wet material and start building up on the inside of the bucket and be a rear to clean out.
/ Bucket Side Walls #3
My Kubota already has a reinforced sidewall and I haven't bent it. If I didn't already have a reinforced sidewall I wouldn't hesitate to weld a piece of steel up it.
/ Bucket Side Walls #4
Yup, the outside is best. Consider using Hardox for the reinforcement plates. You can probably buy precut pieces from a local steel supplier.
I welded the outside of my OEM tractor bucket before I ever used it.
/ Bucket Side Walls #5
I have moved literally MANY tons of rock with my bucket,,,
never a bend,,, except the top,,, a little. :laughing:
Would replacing the side be better than adding dead weight to the bucket,,,
that will always be there? :confused:
A couple pieces of AR,, or some other high strength steel?
/ Bucket Side Walls #6
That sounds like a lot of work to save 7 pounds, which is how much 2 strips of 1/4" x 2" x 24" steel weighs. I'd add some thin strips of Hardox or AR to the edge and call it a day.
/ Bucket Side Walls #7
I wouldn't even bother with hardox or any other hardened steel unless I had it laying around. Mild steel will work and is probably what the rest of the bucket except possibly the cutting edge is.
2019 KUBOTA KX71-3 SUPER SERIES EXCAVATOR (A65053)
2019 KUBOTA KX71-3...
(1) 40 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 40 Yard Roll...
2015 John Deere 210 GLC Excavator (A60352)
2015 John Deere...
2026 MACK GRANITE GR64F DUMP TRUCK (A63276)
2026 MACK GRANITE...
New/Unused Hercules ATV Sprayer (A65583)
New/Unused...
2020 Can-Am Commander XT 1000 R (A62679)
2020 Can-Am...
