Bucket problem
/ Bucket problem #1
stouffserv
Hagerstown, MD
Bobcat 863
I can start my 1999 Bobcat 863 and for 5 minutes it runs and works absolutely great. Then the bucket starts bouncing real bad up and down and when tilting. Eventually the bucket stops working. It will still drive backwards and forwards. It is not low in fluid. I have replaced filter under the cab. A light will blink sometimes, I think it says 'tilt valve'. Any ideas?
/ Bucket problem #2
the problema is in the main valve control presure or in the hidraulic pump is eccesiveli damage
/ Bucket problem #4
I believe you have a separate implement pump for the attachments.
Do you mean that it is bouncing up and down as you move the lever?
Perhaps air in the system. Maybe suction leak at the attachment pump.
Are there any bubbles in the hyd tank?
Can you put a gage on the implement pump and see if you have steady pressure at any time.
A floppy bucket is usually caused by air.
Can you make the relief valve come on?
Do you have separate hyd tanks for the loader, and could the fluid level be low?
Can you move the bucket by hand?
/ Bucket problem #5
The blinking light "tilt valve" is giving you a diagnostic code. Count the number of flashes between each pause, this will help determine if problem is in control handle, wire harness, or tilt valve actuator.
2006 Mack CV713 Granite Tri-Axle Dump Truck (A61573)
2006 Mack CV713...
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
2021 WACKER NEUSON LIGHT TOWER (A63569)
2021 WACKER NEUSON...
2023 Hustler X-One Zero Turn (A63116)
2023 Hustler X-One...
Case Titan 3530 (A63118)
Case Titan 3530...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63118)
2019 Krause...
