Bucket Pivot Won't Take Grease
   / Bucket Pivot Won't Take Grease #1
WranglerX
Super Member
A Little Bit West Of Yosemite NP
MF GC1715
Sort of baffled here, have a lower pivot pin on FEL that wont take grease, have had pivot pin out, and zerk is good, channel through pin is good (clear), exit port in chanel/pin is good (clear) but won't take grease.... Seems that the eye on loader frame is hard pressed against the pin and effectively forms a "seal" on grease port of pin.... Sort of thinking of taking Dremel tool and putting small groove around pin so grease has channel to go around pin like in image below...
Anybody have different idea/solution....
   / Bucket Pivot Won't Take Grease #3
If it's possible to get the hole the zerk goes in straight up, clean out hole, then fill with a liquid penetrate of any kind. Put zerk back in and try to pump grease in. A good gun should have at least 10K psi and that should be enough to force the liquid through and the grease will follow.
If it's at a 90º angle, remove zerk, clean hole then make a half dam with grease, fill with penetrate, replace zerk and try to pump grease. I've had a 99% success rate using this method.
Pin channels are clean and open, grease flows fine with pin out of FEL....
And my hand grease gun will only go to 3000psi...
   / Bucket Pivot Won't Take Grease #5
Try the penetrate, if it won't take grease, cut the groove.
   / Bucket Pivot Won't Take Grease #6
Can you drill the cross hole all the way through If pin isn’t too hard? This allows for load on one side creating grease clearance on the other. Groove does similar thing.
   / Bucket Pivot Won't Take Grease #7
I have one zerk that WILL NOT take grease while the FEL/grapple is in the resting position. It's a PITA. I start the tractor - raise the FEL slightly - rotate the grapple slightly - Whala - the zerk works fine now.
DUH!.... Didn't try that!....
BINGO.... Changed angle of bucket to loader arm and it takes grease......
   / Bucket Pivot Won't Take Grease #10
I bought a HF zerk clearing tool. You load it with ATF and hit it with a hammer to break through any solid grease packed fitting. My help somebody reading this that has a similar unrelated problem with a frozen zerk.
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A55851)
2025 84in Dual...
2017 Ford Fusion Sedan (A55853)
2017 Ford Fusion...
2006 CATERPILLAR 320CL EXCAVATOR (A51406)
2006 CATERPILLAR...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2011 New Holland B95B Cab MFWD Loader Backhoe (A55314)
2011 New Holland...
2016 MACK CXU613 MID-ROOF SLEEPER (A55745)
2016 MACK CXU613...
