Bucket mods
/ Bucket mods #1
jhunter124
Northern California
2007 John Deere 3320
Started working on upgrading the bucket for my 3320. I did a lot of reading here and combined a few ideas from others. I wanted chain hooks, a receiver, a slip hook and some rings for ratchet straps. I also added 3/16 plate on the sides to thicken the cutting edge and provide a better anchor for the Markham tooth bar. The top of the bucket got 1 1/4 in pipe that had been sliced lengthwise and a 1/4 by 4" flat bar welded on. Let me know if I should change or add anything before she gets some paint.
/ Bucket mods #2
Did you start out with the light duty bucket, or the heavy duty?
/ Bucket mods #3
Nice looking job.:thumbsup::thumbsup:
The Clamps; will you remove them before painting?:laughing::laughing:
Did you add extra skid plate on the bottom of the bucket?:)
/ Bucket mods
It is the light duty bucket so it needed some help. Never thought about bottom skids. Where are they put and how thick should they be?
/ Bucket mods #5
Nice work, you made a HD bucket out of a Light duty. all those acs are going to serve yo well. I am especially fond of the center mount receiver hitch :thumbsup:
JB
/ Bucket mods #6
Can I ask, what do you guys do with those bucket mounted receiver hitches? I couldn't think that you are moving trailers around with the bucket, but do you?
/ Bucket mods #7
Depending on the width of your bucket I would put at least 2 on a 4' and at least 3or 4 on anything bigger. Run them from the back of the cutting edge to the heal of the bucket. Stitch weld them on so when they wear thin you can get them off easy and put more on! 3/8"to 1/2" thick x 3" wide
I like your rings, nice!:thumbsup:
/ Bucket mods #8
Absolutely, Not going down the road, mostly jockeying them around, storing them out of the way etc. Very handy.
This was an unconventional use, before I got a dump trailer, this set up helped me move loads of dirt a few hundred feet. much faster than running bucket after bucket full.
Just park trailer, load it with loader and grab it with hitch, drive to where needed and lift/dump.
JB
/ Bucket mods #9
JB
Nice job. I'm getting ready to weld some hooks on my new L5740 and I like the 2 inch receiver with the hook welded to the top.
/ Bucket mods #10
Whatever you want. Put a hook in there, a pulley, a boom pole, a hitch, a d-ring, a vise. Pretty much anything that you can weld or bolt to a 2" piece of square tube. Only limit is how strong your bucket/FEL is.
/ Bucket mods #11
JB, your "dump trailer" idea is fantastic. I had never even considered doing anything like that but after seeing your pics I am a believer. You might have just solved a fairly large problem for me!
/ Bucket mods #12
A VISE? Now you gave me another project :)
Glad I could help :)
JB
/ Bucket mods
The bucket has only two skids on the bottom so I will add a few
more. Nice boom pole idea JB, that is now on the list of things to build along with vise.
/ Bucket mods #14
This might come in handy when you are out in the deep woods, and nature calls. Plug this in, and add bucket, and you know the rest.
2 in receiver Potty seat.
2 in receiver vise
/ Bucket mods #15
I think I would weld in another set of hooks upside down, to allow the chain to lift things from the back side. This is where you can lift the most weight, and by curling the bucket back, you can add to your lifting capability. This also prevents the chain from bending the lip of the bucket.
/ Bucket mods #16
Nice job! I'd use more weld on those ring retainers, though.
/ Bucket mods #17
2 in receiver vise
What do you need the bucket for LOL
/ Bucket mods #18
I added the usual hooks, two on the upper lip and one on the heel center line for heavier lifts. Also built a bolt-on "snow screen" to get more capacity for moving snow, and bolt-on snow skids for the bottom to leave some gravel on the driveway in winter. The next project is the removable forks.
Sean
/ Bucket mods #19
HiTechTed
Well, if you have it on your tractor bucket, you surely don't want to crap in your tractor bucket, so it becomes necessary to put a bucket in your bucket. .
/ Bucket mods #20
HiTechTed
I dunno, I kinda like hanging on to a small tree with one hand, hoping and praying it doesn't break :laughing:
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
2017 Ford Fusion Hybrid Sedan (A61574)
2017 Ford Fusion...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59911)
2016 FREIGHTLINER...
2008 Ford F-250 Ext. Cab Pickup Truck (A61573)
2008 Ford F-250...
2018 John Deere 5125R Tractor (A64047)
2018 John Deere...
