Bucket issues
/ Bucket issues #1
snake699
Satoh Beaver
I have a John Deere 790 with a 300 loader. Replaced all arm and bucket cylinder seals. New hoses. Arms lift fine under load. Bucket will tip and tilt but does not hold. Is one of the valves in the control valve leaking past. Any help appreciated. I have shimmed the relief valve to increase lift pressure.
/ Bucket issues #2
Set bucket flat on the ground and unplug the quick disconnects for curl and dump. Raise the loader and watch to Confirm there are no external leaks. If bucket dumps then a cylinder seal is leaking. If it doesn’t move the valve is leak path.
2022 JCB Fastrac 4220 217HP 4WD Agricultural Tractor (A66734)
2022 JCB Fastrac...
2012 Ford Transit Connect Cargo Van (A66736)
2012 Ford Transit...
2020 Deere 670GP (A64126)
2020 Deere 670GP...
2006 Ford F-450 Crew Cab 9ft. Stakebody Flatbed Truck (A66736)
2006 Ford F-450...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
2017 Ford Escape SUV. (A66738)
2017 Ford Escape...
