Bucket hooks
/ Bucket hooks #11
Kevin,
On my 4310, I mounted two slip style tow hooks, one on each side of the top of the bucket. I used these cause I already had them, taken off a 4 wheel drive truck I had sold a long time ago. I drilled holes through the top of the bucket as close to the side as I could get, and still leave room for the mounting bolts/washers. I cut two pieces of 1/4" X 2" X 2" angle iron and fit them into the inside upper corner of the bucket to reinforce the mounting points for these hooks. The angle is welded to the underside of the top and the inside side of the bucket, and the tow hooks are bolted through both. This really gives me a strong mounting point, and I don't worry so much about bending the top of the bucket if I have a heavy off-angle pull on the hooks.
For the center of the bucket, I bought a bumper mount, receiver hitch, for a pickup truck from Wall Mart. About $35.00. This is bolted through the top of the bucket at the center, and is mounted upside down. I am going to cut a piece of 1/4" flat steel to weld into the underside of the bucket, under this hitch, as the center of the top of the bucket is not very strong and will bend/deflect under much of a load. I can hook my chain hooks to the safety chain holes in this hitch, mount a tow hook adapter into the hitch hole, or use a trailer ball mount in the hitch to move trailers. I also plan on making a boom pole that will mount into this hitch, bear on the bottom edge of the bucket, and be braced to the two outside tow hooks, to set light wood trusses, etc., but haven't gotten to that yet.
Having this hitch mounted to the center top of the bucket will allow me to use many different attachements on the bucket. So far I have used a tow hook, trailer hitch ball mount, electric winch mounted in a receiver cradel, and chains with hooks on the ends run through the outside edge hooks and hooked to the safety chain holes on the hitch to hold them in place.
This set up can be as versatile as your imagination, and it's easy to make your own impements to mount to it.
Just my variation on what a lot of others here have done.
Have fun,
DT
/ Bucket hooks #12
Kevin
I show off this hook reinforcement all the time. If you knew me you would know I had nothing to do with thinking of the engineering principle /forums/images/graemlins/blush.gif. Full credit to a JD tech at my dealer
/ Bucket hooks #13
Front view
/ Bucket hooks #14
Pete,
<font color="blue">I show off this hook reinforcement all the time.</font>
I'm guilty also. I have shown mine several times. The Tech did a good job.
/ Bucket hooks
DT
Got any pictures of what you have so far? The ballhitch sounds useful for jockying trailers around.
Kevin
/ Bucket hooks #16
A center hook is what you will probably use the most.
Where off center hooks get people in trouble is when they hook on to a heavy load on one side only. This can tip a tractor over quickly.
However. there are times where it is better and more stable to hook your load to both side hooks for distributing the load and to keep it from swinging while moving. These can also help to secure a bulky load in the bucket.
Some folks only mount one center hook, but most do all three. Just don't hang a load from one side only.
Rip
/ Bucket hooks #17
<font color="blue"> A center hook is what you will probably use the most.
</font>
For me it depends on whether I am pulling/lifting or holding something in/against the bucket.
In the latter case I use the side hooks a lot. I've attached a picture of how side hooks work for me. /forums/images/graemlins/smile.gif
/ Bucket hooks #18
Henro: awesome idea with side hooks. I was wrapping some logs todayand went under the bucket for the wrap. I have hooks on the outside top only. If side hooks are strong on a HD bucktet I'll look at that. Thanks for that tip
/ Bucket hooks #19
If you only have two hook and you want to pull from the middle, use a chain shortener or hook the chain to itself in the middle.
/ Bucket hooks #20
Good thread. I wish I had thought of hooks when I bought. Dealer didn't mention them either, darnit. But I've gotten some good ideas from yall. I especially like the idea of mounting the receiver hitch in the top middle for versatility. If anyone has that setup and could share some pics that woud sure be nice.
Thanks,
Moon of Ohio
2017 Ford F-150 Ext. Cab Pickup Truck (A60352)
2017 Ford F-150...
2019 FORD F-150 XL EXT CAB TRUCK (A59823)
2019 FORD F-150 XL...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
(INOP) MASSEY FERGUSON 451 TRACTOR (A59823)
(INOP) MASSEY...
KOMATSU WA270 (A58214)
2017 JOHN DEERE 333G (A60736)
2017 JOHN DEERE...
