Bucket hooks on round top bucket
   / Bucket hooks on round top bucket
Thanks for the replies guys. Many good ideas. I really don't want them on the flat part because they will be angled such that chain can slip out. Not an issue when you have weight hanging from it but I would prefer to have gravity in my favor especially when trying to use the hooks to secure things in the bucket.
   / Bucket hooks on round top bucket #13
I'd just weld on the back below the curve on the flat area closest.
For sure with the curved top edge you wont kink it with heavy loads.
Your only concern could be tear out if thin metal. To prevent that first weld the hook to a , say, 3 X 4 inch 1/4" plate and then the plate to your bucket.
Another solution would be the bolt on hooks sold on TBN with an inner backer plate.
Your best location for safe lifting is center of the bucket.
   / Bucket hooks on round top bucket #14
I welded a plate behind the tube to give more support and welded a slip hook onto it. The similarly a grab hook on each side.
   / Bucket hooks on round top bucket #15
Like others have said, I would weld on a plate to reinforce the bucket then weld the hooks on. I would put three hooks on. My tractor only has one on each end. I wish it had one in the middle because it would be less likely to tip the tractor with heavy loads.
   / Bucket hooks on round top bucket #16
Mine's rounded. I found a normal (non-weld-on) hook worked well.
   / Bucket hooks on round top bucket #17
My tractor also has regular chain hooks. I have been unable to break then off, so they must be pretty strong.
It is all relative. The lift capacity of our tractors doesn't really tax a G70 3/8 hook. WLL of a 3/8 hook is 6,600 lb. that means break point is 13,200 lb. With our 3,000 lb +/- lift we aren't coming close to hurting them.
   / Bucket hooks on round top bucket #19
The strength of the hook is way more than a small tractor can pull. It is harder to get a strong weld with a regular hook VS a weld on hook.
   / Bucket hooks on round top bucket #20
WLL is generally 1/4 of break force, not 1/2.
2007 Sterling L7500 Terex Commander C6060 60ft Insulated Derrick Digger Truck (A55973)
2007 Sterling...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
2014 Ford Fusion SE Sedan (A56859)
2014 Ford Fusion...
2025 BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
