Bucket Hooks on NEW XR4145HC
   / Bucket Hooks on NEW XR4145HC #11
If you can weld, and have a decent welder, there's no need to buy bolt-on hooks. I bought three G70 weld-on hooks off fleabay, then found them cheaper at a local welding shop... My bucket is 3/16" thick across the top, so I welded them directly on. (See pic in post #2 of my thread below.) If you have a lighter bucket, then welding the hooks to a 3"x3" or 4"x4" piece of 1/4" plate, and welding that to the bucket would be better.
If I did it again, I'd weld the center hook first, and then use a 5/16" chain to position the two outer hooks so all three can engage the chain at the same time. My hooks ended up spaced just wrong, so the chain is between two links in the middle if I hook it semi-tight across the bucket... Live and learn... :)
Have fun with your new tractor!!
   / Bucket Hooks on NEW XR4145HC #12
Rather than hooks, I decided I would get more use out of "D"-rings,,,
I got them off of eBay,, I selected D-rings because I prefer rope to chains for most lifting.
The D-rings will work with chain, also,,
That is a 5/16" and a 3/8" chain on the ring.
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
206707 (A58375)
206707 (A58375)
2015 Toro Z Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2015 Toro Z Master...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
43055 (A55851)
43055 (A55851)
