Bucket Hooks on NEW XR4145HC
   / Bucket Hooks on NEW XR4145HC #11
If you can weld, and have a decent welder, there's no need to buy bolt-on hooks. I bought three G70 weld-on hooks off fleabay, then found them cheaper at a local welding shop... My bucket is 3/16" thick across the top, so I welded them directly on. (See pic in post #2 of my thread below.) If you have a lighter bucket, then welding the hooks to a 3"x3" or 4"x4" piece of 1/4" plate, and welding that to the bucket would be better.
If I did it again, I'd weld the center hook first, and then use a 5/16" chain to position the two outer hooks so all three can engage the chain at the same time. My hooks ended up spaced just wrong, so the chain is between two links in the middle if I hook it semi-tight across the bucket... Live and learn... :)
Have fun with your new tractor!!
   / Bucket Hooks on NEW XR4145HC #12
Rather than hooks, I decided I would get more use out of "D"-rings,,,
I got them off of eBay,, I selected D-rings because I prefer rope to chains for most lifting.
The D-rings will work with chain, also,,
That is a 5/16" and a 3/8" chain on the ring.
Deere 310SK (A57148)
JOHN DEERE 470G LC EXCAVATOR (A60429)
JOHN DEERE 470G LC...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
2013 HAMM GRW280I-30 8 WHEEL PNEUMATIC ROLLER (A60429)
2013 HAMM...
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
