bucket breakout force
/ bucket breakout force #1
ericbx1500
Michigan
BX2380, scotts 48
can someone explain what bucket breakout force means /forums/images/graemlins/confused.gif
/ bucket breakout force #2
Break out force is the amount of force a FEL has to roll the bucket back, when the bucket is stuck in a pile of dirt.
/ bucket breakout force #3
Eric,
Breakout force is the amount the loader can pry up when the bucket is placed flat on the ground. Loader breakout means that only the loader lift cylinders are used to pry up. The Standard used for CUT type loaders calls for load being pried up to be applied at the bucket pivot loacation. On large constuction equipment the curl breakout force is also usually provided. This requires a bucket to be in place and the load being pried is at the bucket edge or some reference location. Curl breakout means that only the bucket curl cylinders are used.
JackIL
HARGEE 18' BOGGIE AXLE METAL TRAILER (A63291)
HARGEE 18' BOGGIE...
2009 International 4300 Box Truck 24' (A62613)
2009 International...
New/Unused Quick Attach Landhonor Hydraulic Winch (A65583)
New/Unused Quick...
2015 Ford Explorer AWD SUV (A64557)
2015 Ford Explorer...
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
2016 CATERPILLAR CP44B PADFOOT ROLLER (A65053)
2016 CATERPILLAR...
