bucket breakout force
/ bucket breakout force #1
ericbx1500
Michigan
BX2380, scotts 48
can someone explain what bucket breakout force means /forums/images/graemlins/confused.gif
/ bucket breakout force #2
Break out force is the amount of force a FEL has to roll the bucket back, when the bucket is stuck in a pile of dirt.
/ bucket breakout force #3
Eric,
Breakout force is the amount the loader can pry up when the bucket is placed flat on the ground. Loader breakout means that only the loader lift cylinders are used to pry up. The Standard used for CUT type loaders calls for load being pried up to be applied at the bucket pivot loacation. On large constuction equipment the curl breakout force is also usually provided. This requires a bucket to be in place and the load being pried is at the bucket edge or some reference location. Curl breakout means that only the bucket curl cylinders are used.
JackIL
2019 John Deere 4044M (A62177)
2019 John Deere...
2019 Autocar Xpeditor Garbage Truck (A62613)
2019 Autocar...
15K TRIPLEX PUMP (NONE TITLED) (A63569)
15K TRIPLEX PUMP...
Tufline Box Blade (A64047)
Tufline Box Blade...
Adams Weight Hopper (A63688)
Adams Weight...
Worksaver 48" Tractor Grapple w/ 12V Actuator (A64047)
Worksaver 48"...
