Buck Fuel Filter & Oring
/ Buck Fuel Filter & Oring #1
Steve777
Just changed out the fuel filter in my diesel Buck with a CarQuest #86264. Had to put a new Oring on the stem that fits into the filter top as the old one stuck to the old filter and came out with it. This Carquest filter that I had was a pretty tight fit, which makes we wonder if it is the right one (granted it was about 0deg F outside that might have had some effect). So my questions are:
What is the right fuel filter for a diesel Buck tractor, and which brand(s) seem to work best?
What size Oring should one use on the stem that fits into the filter?
TIA
/ Buck Fuel Filter & Oring #2
I also have that tight fit problem.
I believe that the plastic bowls actually shrink somewhat over time as I was fortunate enough to have obtained a Mitsu original (in bag with P.N.) and it also was real tight.
So I now no longer use the filter in the bowl and let the bowl simply act as a separator and have cut the fuel line downstream and add an in line paper filter to catch fine particles.
No problems over 7 years with that setup but I do change that in line every year as it is very cheap.
The Oring is oddball and I had to make one up to fit.
/ Buck Fuel Filter & Oring #3
Napa's filter is 3264, wix 53264 and Fram cg9271. I can supply an original equipment filter and new bowl if necessary. I have found that most of the aftermarket filters are either a little big or a little small. Call 1-800-609-5110. Bill - satohparts.com
2019 F150 (A61306)
2019 F150 (A61306)
QA 72" Grapple Attachment (A64126)
QA 72" Grapple...
2015 Ford F-250 Knapheide Service Truck (A64556)
2015 Ford F-250...
Cultivator (A62613)
Cultivator (A62613)
2017 Peterbilt 579 (A64127)
2017 Peterbilt 579...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
