Buck Fuel Filter & Oring
/ Buck Fuel Filter & Oring #1
Steve777
Just changed out the fuel filter in my diesel Buck with a CarQuest #86264. Had to put a new Oring on the stem that fits into the filter top as the old one stuck to the old filter and came out with it. This Carquest filter that I had was a pretty tight fit, which makes we wonder if it is the right one (granted it was about 0deg F outside that might have had some effect). So my questions are:
What is the right fuel filter for a diesel Buck tractor, and which brand(s) seem to work best?
What size Oring should one use on the stem that fits into the filter?
TIA
/ Buck Fuel Filter & Oring #2
I also have that tight fit problem.
I believe that the plastic bowls actually shrink somewhat over time as I was fortunate enough to have obtained a Mitsu original (in bag with P.N.) and it also was real tight.
So I now no longer use the filter in the bowl and let the bowl simply act as a separator and have cut the fuel line downstream and add an in line paper filter to catch fine particles.
No problems over 7 years with that setup but I do change that in line every year as it is very cheap.
The Oring is oddball and I had to make one up to fit.
/ Buck Fuel Filter & Oring #3
Napa's filter is 3264, wix 53264 and Fram cg9271. I can supply an original equipment filter and new bowl if necessary. I have found that most of the aftermarket filters are either a little big or a little small. Call 1-800-609-5110. Bill - satohparts.com
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
2021 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
2014 Ford Transit Connect Van (A61573)
2014 Ford Transit...
2019 Ford F-150XL (A60462)
2019 Ford F-150XL...
2017 FORD F-350 SUPER DUTY (A65643)
2017 FORD F-350...
