Bubbling around injector
/ Bubbling around injector #11
Does your manual instruct this? A guy down the road almost lost his finger to gangrene from fuel penetration trying to tighten inj line nut on running JD. If you don't have bleed screw on top of housing, leave filter loose until it overflows. Bleed supply line at pump and you should be running in 10 revs or less when cranking it. It shouldn't be necessary to crack inj lines.
Sdlanch SDLGM1220F (A60463)
Sdlanch SDLGM1220F...
(INOP) 1996 CASE 580L BACKHOE (A59823)
(INOP) 1996 CASE...
Sdlanch SDLD25 (A60463)
Sdlanch SDLD25...
Kubota RTV X900 (A53317)
Kubota RTV X900...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
2013 PETERBILT 389 (INOPERABLE) (A58214)
2013 PETERBILT 389...
