Brush Puller Project
/ Brush Puller Project #1
rwork
Platinum Member
Mississippi Gulf Coast
Kubota B6100 LS R3039H
I'm wanting to build a brush puller, and I'm working on the design at this point.
Can someone tell me what type pin and bushing I need. I want to use a greasable pin / bushing similar to the one shown on my grapple, for my pivot arm, only larger.
Just don't know what it is called, so that I can search for them.
Thanks
/ Brush Puller Project #2
/ Brush Puller Project #3
I ordered a greasable pin the same as on on my tractor; then found a shaft coupling the same size and used it for the bushing. After welding the bushing in I had to use an expanding reamer to true up the bushing. The couplings for a
1 1/4 "shaft are over 3" long. For short welded in bushings; shaft couplings are better as they are thicker wall and distort less when welded.
Ron
2018 Caterpillar D5K2 LGP Crawler Tractor Dozer (A61572)
2018 Caterpillar...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2007 Utility Trailers Mfg. FS2CHA 48ft. 40 Ton T/A Flatbed Trailer (A61573)
2007 Utility...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
2025 48in Drum Mulcher Skid Steer Attachment (A61572)
2025 48in Drum...
2000 Jeep Wrangler 4x4 SUV (A61574)
2000 Jeep Wrangler...
