Brush Hog
/ Brush Hog #1
dtd24
Schenectady, NY
98 JD 1070
I have a 99 1070 JD w/ 440 FEL and 8B hoe. I took off my backhoe and I hooked up the 3 point hitch for the first time. It went good, I think I will be able to do it quicker next time. I installed the brush hog, and it works like a champ. I went though a couple of shear bolts though. It says to run the hog at 540 pto rpm, on my tractor that is 2610. WOW ! I usually run it a bit lower. Runs great , but fast for some of my terrian. Gotta get use to it I guess.
/ Brush Hog #2
Welcome to the forum.
>>I went though a couple of shear bolts though<<
Did you hit something or did you break them trying to engage the cutter?
>>Runs great , but fast for some of my terrian.<<
Not sure what you mean there. Try a lower gear, perhaps??
/ Brush Hog
Shear bolts......yeah. Well, the first one busted because I engaged the pto with rpm's too high. The second one was from hitting a car rim. Ouch. The previous owner left me all kinds of goodies all over the place.
I understand the gear is the only thing that controls the speed of the tractor when using the pto. I thought I had it in low 1. Gonna try some more toinight.
/ Brush Hog #4
I am not familar with your tractor. Maybe someone who is will chime in here. Do you have a range selector as well as a gear shift? I would imagine, if you do, low range and low gear would just creep along.
/ Brush Hog #5
I'm not familiar with your tractor.. but if it has 1-2 stage clutch.. lower rpm, and use clutch to feather pto into operation. if independent, lower rpm, and see if your manual has a 'slow/feather' sequence for engagement.. etc..
Soundguy
/ Brush Hog #6
You DO NOT HAVE TO RUN THAT HOG AT 540 PTO RPM for a good cut. You can experiment with gears and rpm on the tach. I've got a 60hp 4wd with a HD 7ft cutter on the back. PTO speed of 540 is achieved at 2000rpm on the tach. I usually run this hog at about 1500 to 1800rpm on the tach in 3rd or 4th gear (8speed). If I was cutting 3" saplings I'd be in a much lower gear thougjh....BobG in VA
Long 350 Tractor (A62613)
Long 350 Tractor...
Ripper Tooth Excavator Attachment (A61567)
Ripper Tooth...
2012 International 4300 Reefer Truck (A63689)
2012 International...
Linx UT357714T 14ft Trailer (A65640)
Linx UT357714T...
NEW Wolverine 66" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 66"...
Caterpillar D6N XL Crawler Dozer (A65579)
Caterpillar D6N XL...
