Mowing brush hog vs finish mower
/ brush hog vs finish mower #1
StableBoy
Is there a general rule about which one requires more HP to operate (assuming identical widths) in tall grass?
/ brush hog vs finish mower #2
The brush cutter needs more horsepower...that's a fact. They generally weight about 200 lbs. more the same sized finishing mower.
Of course, the intended purpose of the cutter is to work in areas that have tall grasses or brush...that would tear a finishing mower up pretty quick.
The rule of thumb I've read on TBN (and my dealer concurs) is 5 HP per foot of cutter width. Now, I've never heard it expressed as PTO HP or Engine Gross HP.
As far as finishing mowers...never hear any specific requirements, other then that which is recommended by the implement manufacturer.
That said...I run a 5' cutter through moderate to heavy brush (and saplings) with a 24 PTO HP Deere 790. That's 4.8 PTO HP per foot and it works mighty fine. However, I used that same 5' cutter behind a Deere 670 (16.5 PTO HP) which also did fine. That's 3.3 PTO HP per foot.
The 790 does handle the work better, but the 670 did a heck of a job. That cutter, per Land Pride, should be ran behind a 20 HP (minimum) tractor. Land Pride doesn't specify PTO or Gross HP, but I'm assuming they mean PTO HP.
As far as finishing mowers...I figure if the PTO can pick it up, the tractor can run it. I'm using a 5' mower currently. I could easily run a 6' mower...I'd even consider a 7" mower if it didn't overload the 3PH capacity. Of course, I don't have the $$$ for a bigger mower, but I know the tractor can handle more then I've got now.
/ brush hog vs finish mower #3
My bush hog is direct driven off the gear box while my finish mower is belt driven off the gear box. There is a huge loss of HP through the belt and requires more HP to get the same job done.
/ brush hog vs finish mower #4
Roy J, I have a 6 foot finishing mower. I pulled it with a 600 Ford for years but in thick grass, not weeds it was all the Tractor could pull and would bog down at times. I now pull it with a 4330 Kubato and it don't seem to know it's behind it. So in my opinion a finishing mower it just as difficult if not more difficult than a brush cutter to pull. Once that one big blade gets spinning on a brush cutter it's just hard to slow down. Those three small blades spinning under my finishing mow just don't have the counter weight effect as the brush cutter. Your assesment of the HP per foot sounds like a good rule of thumb. Another thing to take into consideration is my finishing mower is set much lower than the brush cutter. Just sounding off a little......Merry Christmas.....Teddy /forums/images/graemlins/laugh.gif
/ brush hog vs finish mower #5
</font><font color="blue" class="small">( Once that one big blade gets spinning on a brush cutter it's just hard to slow down.)</font>
I have to agree with that. The blade builds a high level of kinetic energy by the formula Kinetic Energy = Mass x Velocity. There are actually 2 blades attached at pivot points to a rotating pan. If a blade does hit something capable of absorbing all that inertia, the blade simply pivots and slides off, ready for the blade on the opposite side to take another swordlike chop at the obstacle.
The finish mower is designed to give a smooth cut to turf. Its little blades are not designed to overcome resistance. If you hit something with high stationary inertia, the blade, having a low amount of kinetic energy and not being able to swivel, simply stops which stalls the engine.
Comparing these implements to each other is like comparing hair trimming scissors to a machete or meat cleaver. They are for completely different purposes. You could use the RFM in rough stuff, but you certianly will not get optimum results.
/ brush hog vs finish mower #6
When ya kill the PTO on a brush hog vs. a FM., how much longer do the blades spin on the cutter... Its not the size or weight of the blade, its the drive. Belts eat HP.
And I agree its like comparing apples and oranges. Two different tools for different jobs.
/ brush hog vs finish mower #7
My RFM winds down quickly...the cutter spins for 60 seconds or so...
Maybe the belt eats HP, but the cutter is built to go through much thicker, heavier stuff....and I've never had my mower
bog the tractor down. The cutter does, occasionally. Of course, I'm mowing a finished lawn with the mower...at worst, 5" tall. I wouldn't even use a finishing mower on grasses much taller or thicker then a lawn...not built for that kind of work.
Take a look at the manufacturer's reccomendations...see what you find...
/ brush hog vs finish mower #8
Stable boy, Hands down in my opinion the finishing mower is most difficult to pull and eats up more HP. I've used both. Just my opinion and I respect the others. Maybe I am going to learn something here I know I need to. Each are for different tasks but are similar and I think they can be compared. Merry Christmas /forums/images/graemlins/laugh.gif Teddy
/ brush hog vs finish mower #9
</font><font color="blue" class="small">( The brush cutter needs more horsepower...that's a fact. They generally weight about 200 lbs. more the same sized finishing mower.)</font>
Not trying to start anything here... but I would agree with others that a belt driven FM would require more HP. But like you say... a BH is used for rough cutting taller/larger stuff and the FM is used for a smooth cut and not designed to handle what a BH can. So I think it would depend a lot on what you are using and what you are using it on.
</font><font color="blue" class="small">( The rule of thumb I've read on TBN (and my dealer concurs) is 5 HP per foot of cutter width. Now, I've never heard it expressed as PTO HP or Engine Gross HP.)</font>
I "thought" is was 3 PTO hp per foot but very well might be wrong. I recently bought a B7300 that is 16hp and 12.5 PTO hp. I am looking to buy a 4ft brush hog. It is supposed to be able to run a 4ft brush hog and the math works out that only 12 PTO hp would be needed to do so. I can't imagine that it wouldn't run a 4ft hog. If it was 5 PTO hp thats needed it would be rendered useless for mowing as I don't think you're going to find a 2' hog! /forums/images/graemlins/cool.gif 5 engine hp per foot would be closer but even at that rate my tractor still wouldn't pull a 4ft. All that said... I think 3 PTO hp per foot is a good figure to work from.
Just my opinion! Merry Christmas everyone! /forums/images/graemlins/cool.gif
/ brush hog vs finish mower #10
</font><font color="blue" class="small">( 5 engine hp per foot would be closer but even at that rate my tractor still wouldn't pull a 4ft. All that said... I think 3 PTO hp per foot is a good figure to work from.
)</font>
I think you could run a brush mower with 3 HP per foot, but you won't be mowing very fast.
If you want to mow with any speed at all I would want at least close to 5HP/foot minimum
Just my opinion
/ brush hog vs finish mower #11
</font><font color="blue" class="small">( I think you could run a brush mower with 3 HP per foot, but you won't be mowing very fast.
If you want to mow with any speed at all I would want at least close to 5HP/foot minimum)</font>
There is no dought that the more hp the better. I guess I am speaking more of in terms of 30hp and less tractors. My neighbor has a Mahindra 40hp with a 6ft hog and can cut down anything in his way at any speed and not have a problem. If you've got a 40+ hp tractor you can just about buy whatever you want and not worry about the tractor being able to use it. But for the sub CUTS and CUTS I think the 3 PTO hp rule is a reasonable formula.
/ brush hog vs finish mower #12
</font><font color="blue" class="small">( When ya kill the PTO on a brush hog vs. a FM., how much longer do the blades spin on the cutter... Its not the size or weight of the blade, its the drive. Belts eat HP.
)</font>
On an MMM or RFM some drive may be lost in friction of pully and belt. Once the blades meet serious resistance the belts begin to slip and burn or the engine stalls. You are partially correct in that the "drive" in the rough cutter is superior because the power is transmitted through steel shafts and gears. Flexible belts on pullys do not transfer the power as efficiently. As far as saying that "it's not the size or weight of the blades", however, that is simply not correct. I am not trying to be unkind here but I do hold a certificate to teach physics. The transmission of energy through the drive system on the rough cutter IS a significant variable, HOWEVER, the mass of the blade and its inertia expressed in kinetic energy, and the pivoting of the blade are very significant variables as well.
/ brush hog vs finish mower #13
</font><font color="blue" class="small">( As far as saying that "it's not the size or weight of the blades", however, that is simply not correct. I am not trying to be unkind here but I do hold a certificate to teach physics. The transmission of energy through the drive system on the rough cutter IS a significant variable, HOWEVER, the mass of the blade and its inertia expressed in kinetic energy, and the pivoting of the blade are very significant variables as well. )</font>
You can feel the drifferance here even when starting to spin the mower.
My engine does not slow down, nor do I feel it when engaging my RFM.
When turning on my brush mower the engine will slow down and at times it will shake the whole machine till it spins up to speed.
/ brush hog vs finish mower #14
Quite frankly, I have no idea which one requires the most horsepower; finish mower or brush hog. However, I had both in the 5' size. I could easily turn the PTO driveshaft by hand on the brush hog, but not on the rear finish mower. Of course, the finish mower had a belt from the gearbox to 3 different spindles. Of course, I always engaged the PTO slowly on either mower and you could definitely tell there was a load on the PTO until the mowers got up a little speed and then either seemed to turn freely.
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
E-Z TRAIL 3400 SEED TENDER (A63291)
E-Z TRAIL 3400...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
2011 Ford F150 (A66408)
2011 Ford F150...
2021 Sol Grand Design BK390 Camper (A62613)
2021 Sol Grand...
2008 Isuzu NPR Box Truck, VIN # 4KLB4B1U48J801742 (A65563)
2008 Isuzu NPR Box...
