Brush hog vs finish mower
/ Brush hog vs finish mower #1
JMER817
Platinum Member
Grass Lake, Michigan
John Deere 4120
I'm going to have approx 3 acres of lawn that I will mow only 2 or 3 times a year. Just want to keep it tamed. I currently have a brush hog that will do the job, but may want to have more of a finish cut so thinking about a finish mower. Will a finish mower handle grass that will be at times 12" tall? I have 35hp at pto and thinking of a 72" rear mower.
/ Brush hog vs finish mower #3
We have rotary cutters and finish mowers, 12" grass will smoke the belts on our finish mower.
/ Brush hog vs finish mower #4
No. I run a 5 ft King Kutter finish mower and once the grass hits 6 to 8 inches I have waited too long. They just aren't made for taller material. My two cents...
/ Brush hog vs finish mower #5
If you do not need to use the Bush Hog for saplings, sharpen the blades a bit with an angle grinder and an improved cut will result.
/ Brush hog vs finish mower #6
Finish mowers do not work well in deep grass and will slip the belts.
/ Brush hog vs finish mower #7
I agree with others that the brush hog would be a better choice for tall grass.
If it were me I would cut more frequently with a finish mower as this will retain a better finished appearance and less weeds problems. Infrequent mowing will lead to weeds taking over your lawn area. I think if you compare the costs vs. benefits that more frequent mowing will be the better long term solution.
/ Brush hog vs finish mower #8
CID Attachments X-treme medium flow brush cutter, doesn't stop at much...
/ Brush hog vs finish mower #9
Kinda of lot ask of finish mower,more so if the grass damp.
/ Brush hog vs finish mower #10
Agree with others. Use a bushhog.
And with sharp blades, and only knocking it down from 10-12" a rotary cutter leaves a pretty good finish already IMO. I actually think when cutting 10" grass, a good rotary cutter leaves a better finish than a finish mower. The only thing the finish mower is better for is rolling terrain, as a bushhog will cut more uneven if the terrain is rolling, since it is basically one big blade. (5 or 6' on a fixed plane)
/ Brush hog vs finish mower #12
Maybe in Michigan mowing three times a year is fine but If your concern is for it to look good seems moot when it's only going to look good 3 times a year the difference between a good and bad haircut is about a week
Just kidding
2021 MK Martin Axis 5-6 Hydraulic Took Arm Tractor Attachment (A66734)
2021 MK Martin...
2014 MAC FLAMELESS HEATER (A68842)
2014 MAC FLAMELESS...
Club Cadet RZT (A64912)
Club Cadet RZT...
2005 JOHN DEERE 310G BACKHOE (A65053)
2005 JOHN DEERE...
Depth Band wheel, Scapers (A68191)
Depth Band wheel...
2017 Bobcat T650 Compact Track Loader Skid Steer (A66734)
2017 Bobcat T650...
