Brush hog rebuild.
/ Brush hog rebuild. #1
SNUFFY 1944
mo
kubota L2500
Want to rebuild a bush hog side panels. My question is can the side panels be straight? Is there a reason that the side panels always curve toward the back? Figured may be something to do with the cutting action of the blades. Would be a lot easier if they could be straight.:newhere:
/ Brush hog rebuild. #2
Older rotary cutters had square decks. Then the rear corners were cut at 45 degrees to save on steel. now most are rounded. Build it however you want and are best able to do.
/ Brush hog rebuild. #3
The angle or rounded backend lets you get closer to objects on a turn.
2018 CHEVROLET TAHOE (A66091)
2018 CHEVROLET...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
Vortex Walk-Behind Paint Sprayer (A64553)
Vortex Walk-Behind...
2023 KOMATSU D61PXI-24 CRAWLER DOZER (A65056)
2023 KOMATSU...
PORTA POTTY (A67714)
2010 Sellick S-100 10,000lb Rough Terrain Straight Mast Forklift (A68183)
2010 Sellick S-100...
